View attachment 238012What is not so nice is, the brake blocks end up around 1.3 mm from the wheels. So there will be a hiatus in the build while I sort something out. I am thinking of 0.8 mm square brass to make overscale brake pads with a better gap.
These horse boxes were built with handbrakes only (1878) and later rebuilt with clasp brakes (1888). Much as I would like to model only the handbrakes, I really have got to tackle the clasp brakes. I have spent a week mulling this over, and finally made a start.
The large spacing for the brake shoes is always going to look wrong. I opened up the push rods for the handbrakes so I could make them longer.
Then I rebuilt the push rods in position on the model, and filled the two gaps with small pieces of fret.
The kit provides tabs and slots to locate the remaining six brake hangers, but the tabs (or if you prefer, the slots) are in the wrong place. So I filed down every tab, and added the rest of the hangers. So all eight hangers are a presentable distance from the wheels.
The instructions suggest assembling the mechanisms for the clasp brakes in position on the model. This seems incredibly difficult so I assembled the first one on the bench. The long link is free to move on all three pivots (despite appearances!), so the assembly articulates.
Needless to say, having put the brake hangers in sensible positions, the two pairs of links are too long.
I have wriggled my way out of this by cutting the two longer links and then overlapping the cut parts.
Here is a different view of the same assembly.
I wonder, is there a better solution? I feel, if I try to butt-join the cut pieces of link and laminate a reinforcement on the inside, I will make things worse. And, this bodgery isn't going to show from normal viewing angles. But fresh ideas might help me when I do the second set of clasp brakes. Right now, everything including me is well overdue for a bath
