Hi All,
Although Gladiator distribute this kit it has it's origins in the good old Modeller's World range dating from the early days of etched kits. I must have made all of their kits over the years although never bought from them - I was modelling 4mm when they were around.
Anyway, I started with the tender as usual. Nothing much to report here, it's the same as all the other Webb tenders I've built except to add lamp socket holes in the buffer beam, operating self-contained front buffers and my toy-like but operator friendly coupling post at the front:
I then moved on to the engine, starting with the coupling rods as they set the dimensions for the running chassis:
I then soldered up the frames, fitting Slaters hornblocks - no getting away with quick and dirty wire-sprung top hat bearings on this one as the insides of the frames are very visible on this small boilered engine. The front rods are rivetted to the second making a two rod unit - a legacy on the prototype of it's origin as a 3 cylinder compound, the cotter pinned front bearing being made to clear the outside cylinders:
It ran sort of ok, I wasn't really happy with it's very slow running and I didn't want to open up the bearing holes even more, so I'll leave it until the DCC chip is fitted and see if that smooths things out. A bit of a puzzle as I took my usual due care and attention to dimensions, squareness and alignments, which usually works but not on this occasion. Let's see how it pans out:
So I moved on to the footplate - there's still a lot of detail to add to the chassis but I like to get the main sub-assemblies built to ensure it all fits together and there's no dimensional anomalies.
I'll continue on another post to keep within the photo limit...
Allan
Allan
