4mm Monks Ferry LNWR
A start has been made on the handrails for the bracket signal, which I’m basing on a photo of one similar that stood at Woodside:
To give sufficient clearance for the operating wires, I’m providing access from the rear so the arrangement will be the opposite of the photo.
As mentioned, I’ve just used some left over nickel silver wire from the build although finer stuff would have been a better option.
The access rails:
The rear rails (located to the front on the model):
I’ve flattened the ends to sit flush with the dolls. I’ll attempt the same with the front ones.
Thanks for looking.
A tad more progress with an equitable amount of frustration which seems to accompany my spraying these days.
I snatched at a modeling window this afternoon and decided to add a touch of weathering to the signal arms prior to mounting.
A suitable shade of grime was mixed (Tamiya again to avoid frustration, or so I thought) from red brown and black. Annoyingly it stuttered and splattered despite my best attempts at preventing the paint from atomising in the nozzle. Removing the mix, I stripped down the gun once more and poked around with the wirey brushes and stuff that are included in the box. I also removed the tiny, dull metal thing that sits between the nozzle cover and the needle with the spanner provided to let it soak awhile in the alcohol filled lid of its container, only - being a rotten shot! - I missed and it bounced agonisingly slowly off the glass topped table I was using in the garden and disappeared into the abyss which is the grey coloured resin path beneath. I searched in vain for at least half an hour which I knew would be pointless from the start as thing isn’t much bigger the size of a small anorexic ant.
Letting out a deep sigh, I just left everything where it was and retired for a brew to get my head together.
Returning I made a second token and fruitless search for the elusive part before cleaning and reassembling the redundant gun, resigned to ordering a spare part at some time in the future……if I ever get round to it.
Fortunately, I’ve a spare air gun donated by a kind relative a couple of years ago, replete with compressor, hose and attachments so out thry came, but as these things are pretty standard, I just used my own accessories and compressor to save messing round. Then I filled the cup with the paint mix I’d saved and carried on. But nothing happened…..apart from s9ne bubbling in the cup. This is a clear sign if a blockage. Realising it hadn’t been used/cleaned in quite a while, I took a chance and introduced a tad more thinners. The bubbling remained and rose even higher up the cup whereupon on reaching the brim, a giant bubble burst and coated me………….
The air was blue!
Removing the paint mix once again, and returning it to the mixing jar, I stripped the darned thing down and scrubbed and poked every orifice before reassembling and trying again. More bubbles and nothing out of the nozzle. Suspecting for whatever reason that the need,e might be at fault, I stripped down the gun once more and replaced it with the one from my own redundant one. Cutting a long story short, it worked!
So, to the pictures of the arms:
The fronts are only slightly soiled to give the impression that they’re ‘maintained’ but beginning to become care worn as the station and its environs is soon to become abandoned:
The rears, less so:
This evening, I decided to address the handrails by placing them on the bracket where they’ll eventually sit, to work out where the bends would need to be made and where to cut them to length. This was fraught as they’re so frail, but thankfully they and I survived the ordeal.
Here they are (and the rear rails) after having been primed with acid etch:
I returned them to my indoor workshop whereupon I realised I’d forgotten to flatten the ends of those on the landing section.
I’ll sort this hopefully over the next couple of days.
Railway modelling, hey?
Thanks for looking in.
John57sharp
Sorry, but I did let out a snigger when that bubble burst Jon…. I have had all these trials and tribs, my missing piece turned up in the box, yes! The right place! A minor miracle. I sat reassembling a cleaned gun on the decking yesterday, struggling with a little lever guide thingy, while Gilly sat opposite making helpful comments about how hard it will be to find when it drops down between the planks! Pleased to report that it didn’t drop and that the gun is back in service.
Your signals are progressing well, thanks for your commentary and your encouragement elsewhere.
My pleasure, John, and I guess I’m able to appreciate your efforts (or even empathise) more so with my experience of scratch building as relayed. It can be a trial at times.
No worries about your finding humour with all this c’fubble, John: at least some good will have come of it ;) Pleased to read that you avoided the same outcome with your similar incident. Still, there are benefits to working outdoors although I’m busy keeping an eye to the weather of late with our damp instances and overcast skys that drop the odd drop or two of rain, always just as I’m getting into the swing of spraying.
As suspected, the weather soon reverted to normal once the schools broke up. Perhaps I’d be better putting it away until the inevitable Indian Summer arrives! I do hope your garden is benefiting, John.
Anyway, many thanks once again for your kind interest and encouragement which makes it all worthwhile.
Cheers.
Jon
Just a quick note:
I’ve quickly flattened the ends of the handrails in the vice as mentioned and remounted the landing to check:
As suspected, the landing in its designated position fouls the cams on the mechanism so will have to be raised.
Thanks, all, for your interest.
Roger Pound
The constant in railway modelling is that there is always another snag waiting after you think you have everything sorted - a form of masochism we seem to wish to inflict upon ourselves as part of this wonderful hobby, I suspect........:rolleyes:! Keep up the good work, old friend - you are doing splendidly in producing what I know will be fine signals..
Roger :thumbs:
If only you’d warned me sooner, Roger :))
Many thanks for your kind compliment ol’ chum, but remember: I’ve still to take a hot iron to them :eek:
Best,
Jon
Jonte,
As you're using Tamiya acrylic paint, you may be able to recover the spray gun nozzle, by putting it in IPA and leaving it to soak for a couple of days to soften the paint, then gently prodding with a sewing needle, then trying to blowing neat IPA through the nozzle. Repeat as necessary. Failing that try cellulose thinners. I had to soak the business end of my gun in cellulose after Railmatch paint gummed up the nozzle, I got it clear, but I have misplaced the needle whilst sorting out the nozzle.
Jonte,
Sound advice, Phil, so many thanks.
For some reason I’d forgotten about the handy use of cellulose even though there’s an almost full tin on the shelf next to where I keep the brush, the IPA, deionised water and screen wash (don’t ask :rolleyes:). I think it’s because my limited intelligence doesn’t equate acrylics with cellulose (difficulty in thinking outside of the box).
Will give it a go :thumbs:
At the risk of sounding facetious,Phil, apologies in advance, if it’s the nozzle I think you’re referring to. I’d definitely try this but it unfortunately it was lost to the abyss…….. Still, all taken on board.
Jon
Unfortunately, I doubt a magnet will locate it. My bet is, like every airbrush I’ve owned, it’s made of a non-ferrous alloy like nickel-silver or brass.
Do you know anyone that owns a metal detector?
That’s answered that then. I dug out some quite strong neo something or other magnets I’d put away which I’d purchased for the Kirby coupling method some years ago, and began a coordinated search.
Unfortunately, it proved fruitless and so your kind suggestion, Heather, makes complete sense.
Funnily enough, my wife also suggested a metal detector. My late brother had one which I no longer have access to.
No probs, as I’m sure they’re all pretty much a standard size, but thank you for taking the time to share.
Jon
