Thank you .
Nice work, that is the proper way to do it, no need for soldering and cross pins. But quite a lot of work, milling as well, did you make a fixture to turn the crank pin?
All done in the lathe Paul,
First off is bore and ream the centre of the round bar 3.9mm the length of the whole crank axle for the stub axles that will be fitted to the wheels, then turn the first axle to finish dia. and length, next turn the bar down to the outside dia. of the webs and the width of the two webs plus the crank pin.
The bar is now re-chucked off set on one of the jaws, with some packing, by enough to give the crank throw dimension( in this case 7mm, then with caution
take very ,very light cuts as the bar comes round to meet the cutter you have chosen to cut the crank pin, I keep going until I can see and hear that the crank pin is being cut all round, stop the lathe, measure the dia. of the pin and reduce by the required amount ( in this case down to 3/16" dia.)
We now have a round bar with one axle, one circular web and a crank pin turn on the end.
So next job is to turn down the other end of the crank axle, if great care is taken it can be done with the bar re-chucked back centraly in the 3-jaw and then cut off in the vice, over length, and the end cleaned up in the lathe.
The alternative would be to cut the incomplete crank off the bar to rough length, and re -chuck on the turned axle with a 5/32" rod pushed through it ( so the jaws don't distort the hollow axle) and then finish turning the other end of the crank axle.
You now have a solid turned crank axle with circular webs, and a lot of swarf
, I cut these to shape by marking round a plastic pattern and cutting and cleaning up by hand, the wheels can be quatered for the taper pins in a jig.
I hope that makes sense, it would probably be easier with pic's perhaps I'll do so on the next one I make and post it on my work bench post.
ATB, Col.
