BrushType4
Hopefully Oz7mm will come along and explain all.Hi Phill,
Would be nice if you could tell us what colours and in what order they were applied on each piece.
The mock up looks good with the brick paper.
I've been looking at buildings recently and have been put off by the 'scale' mortar joints in embossed or injected plastic sheets. I'm sure if these are scaled up to 12" to 1' you would be able to put your fist in them and climb them without ropes.
The laser cut sheets look good and how deep are the mortar joints? The sheets also look easier to line up the cuts and joints to ensure the bricks are carried around corners properly.
Are O scale laser cut brick sheets available in the UK 'off the shelf' as they appear to be in the US?
David
Can't see the crack in the artwork. Tee Heeee.I've cracked arches
Very impressive I am looking for the base of a signal cabin for WL. I have no drawings but as near as dammit is ok with me as it's gone to the great builders rubble pile in the sky.
Where is 'WL' ?
I'm guessing it'll be a standard post war LMR type box, if so I have drawings for LMR type 5 and more common type 15 signal boxes if they're any help.
That the babyWhere is 'WL' ?
I'm guessing it'll be a standard post war LMR type box, if so I have drawings for LMR Type 5 and more common Type 15 signal boxes if they're any help.
Addendum, ahh Watery Lane, all brick Type 13 (ARP) by the look of things, unless there's another box at Watery Lane?
https://www.flickr.com/photos/roger_sutcliffe/5542711625/
Don't have drawings for the Type 13 I'm afraid.
Been busy cutting windows.....
Hi Richard,Phil
That looks great I know where to come when Croscombe needs some building
We use essential cookies to make this site work, and optional cookies to enhance your experience.
