I realise that not every body has a lathe or access to one but if you farm out the turning work it shouldn't be too expensive.
To cure this as simply as possible I turned the original crank pin nuts (bolts infact) down to round headed and countersunk.
Osgood,Fancy making it two Colin? I've just got back from the ALSMR Show with an identical beast needing the S7 treatment!!
Thanks Steph, if this was a personal project I would probably go for cast wheels, if they are available, I'm not keen on stainless steel.Neat job Col. Not that I'm surprised...
Buffer beams next with satin red, I use this in preference to gloss red as it looks more like faded colour which red paint so often did.
Finally the body is given it's coat of satin black.
I too had that as a problem, but I overcame it by adding a coat of white or light grey over the black before adding the red - worked like a dream.Hi Col., looking very nice. Did you mask off the buffer beams over the primer then apply the red or did you apply the red over the black? I try where possible to mask off as I find that the black darkens the red too much. Looking forward to the weathering report.
Mike,Hi Col., looking very nice. Did you mask off the buffer beams over the primer then apply the red or did you apply the red over the black? I try where possible to mask off as I find that the black darkens the red too much. Looking forward to the weathering report.
With the loco now re-assembled the plates can be fixed in position.
I can recommend the pistol grip and extra water trap.
We use essential cookies to make this site work, and optional cookies to enhance your experience.
