Adrian Tester and the chairs were for Midland Railway.I won't be doing the casting, I'll contract that out. I seem to recall an article in an old MRj where someone cast 7mm chairs.
That answers one question
Are you sure?That answers one question![]()
Strangely I had been re reading that this eveningAre you sure?
Try this:- Extracts from Harvie...
Maybe not readily apparent from this reference, GWR wood keys were handed. If you need to see the full text then let me know.
Yes, that was what I was planning to use for my masters, it seems to be about the best resolution available at the moment.I think ViperHR from Fineline should do for the final version
http://www.finelineprototyping.com/...php?technologies[]=ref&technologies[]=viperhr
We shall seeYes, that was what I was planning to use for my masters, it seems to be about the best resolution available at the moment.
couple of nuts added. This will go off tomorrow and we will see what happens
Im hoping someone can tell me how big my nuts should be
Surely it should be a screw spike anyway?couple of nuts added. This will go off tomorrow and we will see what happens
You are going to hate me, but I think the top surface of the key ought to be better defined - also I'm pretty certain that its top surface should sit slightly above the top of the chair jaw.
Either way I think you need to put a chamfer across the outside edge of the key, which should show across the top edge of the jaw, if you see what I mean. The key isn't tall enough - although I appreciate that the wrong foot of the code 180 makes this rather challenging. The inside top edge ought to be chamfered too, which makes it fit snugly under the rail head, which it looks as if it doesn't on the current model.
Otherwise it looks absolutely superb.
Sorry.......
Oh - your nuts look fine
Interesting, i looked at one in the yard at Hereford and it was a boltAnd held down by these
Interesting, i looked at one in the yard at Hereford and it was a boltI think Graham also had a drawing with a bolt, Its an easy fix either way. My main concern with this first effort is the chair rail fit. Im not entirely convinced it is even the right chair for Wallingford it looks closer to a BR chair. all good fun
