LOL, I think sometimes we tend to make things just a little too fine when in reality they were pretty darn chunky, I was surprised at how thick handrails were, quite a bit larger than I imagined. The rationale behind the beading is to prevent the engine men damaging themselves on the thin side sheeting.Cheers Mick, I'm off to reread your thread and ponder
Ozzys tip is quite easy to do and copper wire is plenty malleable to get in the curves, it must be easy, I did it and the effect is a game changer, I wish I'd done the windows now, and may still well do that and strip out the old etched ones.
One thing I might change next time, is to bend the wire to the right shape first, solder to the copper clad and then file flat, it was quite hard to bend the D section and it kept wanting to roll at odd angles so that it didn't sit flat on the cab sheet, it is a lot easy to bend into tight corners when it's round than when it's D shaped.
It'll be harder on the A3 because of the turn in, but in your case and on say an A4 where there is no turn and you have flat side sheets then it'll be easier to do.
