A Barclay pug in 7mm scale
George M
With the sides complete the body was then boxed up. As ever, very conventional but well thought out slot and tab design made it quite easy to get a solid square body.
Now the real fun begins! Detailing. A few etches , some castings (all brass!) and some wire. A prototype photo was extremely useful here. I changed out the wire for the brake indicators and added a couple of bits of scrap brass to the ends for the indicators themselves. The only omission I've found so far in the kit is that it is short a couple of lamp brackets for the underframe, an easy fix with scrap etch.
The roof is a really nice injection moulded plastic piece. Well, actually 2 to get the length. A bit of cut'n'shut and a small amount of filler got the length right. I like that the centre line is moulded into the inside, makes getting the lamp tops loned up extremely simple. Unfortunately this is where the instructions fail, clearly being adapted from another kit and the quoted spacing is wrong. A little care and attention here required but otherwise no problem.
Beginning to experiment with painting Mansell wheels.
Best regards from Stockholm, George!
A distraction on a tangent: an NBR horsebox resurrected.
George M
While looking for something else, is that not always the way, I came across 2 prototype pictures of NBR horseboxes.
https://rchsimagearchive.org.uk/cac..._RCHS_Logo_Mstr_trans_2.jpg?cached=1716832893
https://rchsimagearchive.org.uk/cac..._RCHS_Logo_Mstr_trans_2.jpg?cached=1728034338
That reminded me that one of the first etched brass kits I built was of one of these, but it had been abandoned for various reasons (the attention span of a cat to be honest). So I dug it out.
It was not a great job anyway, and time had not been too kind to it. I had yet to discover etch primer in those days.
So far I've tackled one side.
Door handles off and thinned down/re-shaped.
Peeled paint patches patched. On this side I think I'll leave the rough edges and paint the metal weathered wood efgect to mimic actual peeled paint.
Transfers. The HRMS Scottish wagon sheet has the correct ones.
Pins and chains on the horse door catches.
Detailed painting (underframe already started in the above photo) and a start on weathering.
Thats a bit better! Once I've finished the other side and the ends a bit of weathering and some microscope slide coverslip glazing.
A pleasant distraction but I really must get back to the Barclay some day ...
