My last loco to post here is a former BR class 11, this is from the Roco model of an English Electric shunter used on Dutch Railways.
Most of the modifications to the body involve removing unwanted detail.
One tool box is shortened.
I used the first coat of primer as a witness coat while hiding the worst of my changes.
The only new details are the handrails.
The wiring for the decoder rather spoils the look inside the cab. One day I might have another go but the pcb is always going to be visible. This decoder is another Lenz Standard V2.
I copied the livery from a photograph of a similar loco being unloaded at a preserved railway.
When I started in H0 I went for Kadee couplers. Then I realised the RTR stock with its NEM pockets on cams needed a rigid coupling to make the close-coupling work properly. So at the moment I have Kadees on the stock for the local preservation society, and Roco Universal ones on the stock for the revenue-earning railway. The Fleischmann close coupling heads create a slightly tighter gap between vehicles and I might end up going for these eventually.
