Time for an update.
I had previously asked
@Terry what glue he used. The answer was Cosmic Shimmer Specialist Acrylic Glue so I ordered a bottle online. It has proved a very nice glue to use with quite a quick grab time. At the same time I also ordered some precision tip applicators which work extremely well with the Cosmic glue and I have managed to abandon using a cocktail stick to apply it. The wire "pricker" was made so I could unblock the applicators nozzle which I have needed to do about once a week:
I hit a bit of a dilema relating to how to physically join corners on these models. A butt joint was the most obvious but would result in either the item being too wide (if the sides overlap the ends) or too long (if the ends overlap the sides). I could find no reference in the supplied Micromodels kit instructions nor anything online.
Eventually I discovered the following extract from the "Making Models in Card" booklet:
It appears I have been making these kits all wrong, from cutting to joining.
For scoring I have used the back of the scalpel blade which if too heavy handed can result in a weak joint. It also tends to damage the printed surface somewhat. I decided to try using an engineer's scriber held at a low angle and the results have been much better as the following exercise will hopefully illustrate.
So how to form 45 degree bevelled edges to the card parts? The booklet mentions sanding the parts once cut, which I admit I have not tried, though I have on occasion resorted to filing/sanding to true parts up. It seemed to me that it should be possible to cut the parts out by holding the scalpel at a 45 degree (ish) angle against a straight edge. Clearly some experimentation was called for. So I put together some basic artwork in Inkscape using 10mm squares. The outline was 0.2mm with the actual 10mm measurement to the centre of the line, if that makes sense:
The first "cube" was made up by cutting the shape along the outside of the external edges, the scoring done with the reversed scalpel blade and the corner joint butted:
When viewed from the side it is obvious that the cube will be 10.6mm wide (2 * side thickness + 2 * half line thickness) rather than the intended 10mm. Note also how the side deforms as the folding process results in an overwide top.
The damage by scoring with the scalpel blade is also very evident as the card actually opens up at the fold resulting in visible white card:
Next I changed my approach. I cut the external joint faces at approx 45 degree trying to use the centre of the printed line:
Scoring was done using the engineer's scriber and has resulted in a much neater finish with less damage and a stronger fold line. I also scribed slightly inboard of the top lines:
The result is far neater and I could probably get away with minimum touching in to hide the while card. The interesting thing is to compare the two cubes side by side, one is visibly bigger than the other. Does this matter? It can as I recently discovered with a model where the firebox would not fit between the sidetanks using my original method, but fitted comfortably using the bevelling method:
So I need to put this to the test on a real model, but which one. I thought I would have another go at the GNR Atlantic featured at the start of this topic however as I discovered the Micromodel kits have overscale track gauge. So should I correct this as part of my build?
Short term I have decided to give a Modelcraft Micromodel as go as they use a narrower inner chassis. That might help me decide whether to adapt the GNR Atlantic. Strangely it also looks as if it might be easier to put together and is pretty close to my preferred scale of 1/200:
So I took an original Modelcraft card and scanned it. I turned off any attempt by the scanner to colour correct the scan and tried to get the scan as close to the original as possible. On previous models I have been using some generic 160gsm card stock off the internet and it is OK but not brilliant, so this time I have printed the model on some Bristol paper (which also claims to be 160gsm) to see how it compares. Once printed the sheet is sprayed with varnish to help seal the inks and provide a degree of UV protection. I will report how I get on.
