Great thread Adam. Spent parts of today, in between sunbathing in the beautiful Spanish sun, reading from the beginning. The weathering & graffiti is superb.
Steve
Thanks Steve. I'm pleased with both. The other day I stumbled on another couple of boxes from the collection containing a Rivarossi
D.245 shunter (these come in a variety of different series: some rod drive, others, like this one, with all the business hidden between the frames). This is a modern, Hornby-produced item and is, aesthetically, as good as one might hope, but mechanically was a bit of a let down. The gearing gives a top speed round about 90mph and all-wheel drive is transmitted by toothed belt which is effective but which has acquired a bit of a set causing slight lumpiness at low speeds.
That said, it's quite nicely engineered, the wheels aren't too bad and it's more than adequately powered; it's just geared for high speed running which for a machine with a top speed (apparently) of 64km/h (40mph) won't really do. And so prompted by a cheque for a magazine article I commissioned a replacement from the now - very sadly - defunct Hollywood Foundry. Compare and contrast:
This is an excellent bit of kit which runs smoothly and, more importantly, slowly. I've run it in on the circuit of set track that passes for a test facility (can't do that in EM!) and I'm currently grappling with how to fit it to the body. Happily the body is plastic so that's relatively straightforward, and a few bits of 60 thou' welded inside the frames serve to locate it. A proper fixing will require a little thought and a bit of scrap etch, I think:
No cutting required and the upper works still fit so no trimming needed there either:
Compared to the real thing, the handrails appear a bit overfed so these will be replaced - the various other handrails are supplied to fit by the purchaser (etched metal, pre-painted) which will make weathering much easier - and yes, that number plate is etched. In case you're wondering, the buffers are only on the one end because you also get alternate buffer beams (without a huge cut out for Euro-style couplings - thoughtfully these also have all the markings applied) so I could check ride height. Fairly simple work so far...
