Well, it’s been a week and I’ve got a finished wheel at last. I hate working in a sweltering, hot workshop and life was only made bearable by having a fan blasting at me.
I started making the holder for the finish turning of the wheel. I wanted a recess in the end so I started off with a bit of 1” steel and cut the recess in the end, then bored it 5mm to take the spigot.
At this point there was a small diversion. The inside workshop had grown like Topsy over the past three years and it was becoming a problem finding a place to put things down and then finding them again at a later date. The hot weather brought things to a head at the weekend, so the shelves appeared.
Now I could find everything - especially the Erikson collets which had been stored in the individual poly bags which they came in from Cowells.
Before I could turn the spigot, I had to know the diameter of the hole in the wheel centre so I proceeded with drilling the centre 3.1mm then opening it out with a 1/8” hand reamer
The hand reamer has a slow taper on its end which helps with starting. If you ream a hole with a hand reamer and get the transition from taper to parallel within the hole, then axle material can be entered for the parallel part of the bore, then requires pressure to push through the taper part of the bore, giving a push fit. I made a collar to fit the reamer then entered the reamer about 0.25mm at a time and tested with a piece of axle material until the material entered by about 1mm. When this point was reached, the collar was butted against the wheel back and locked in place 3with the screw.
This shows the wheel and axle from the other side, showing the distance left for force fitting
While the centre holder was in the chuck, I also turned the 0.3mm boss on the back of the wheel
I then started on the spigot using a nice piece of steel rod salvaged from an old Epson printer. This was the 5mm diameter part which would fit in the main holder part. The brown colour on the steel is the cutting fluid I'm using, applied with a brush. It stinks.
The part was then reversed in the collet chuck and the spigot end turned to size to be a nice fit in the reamed axle hole in the wheel centre. I did this by making the spigot over length then got the whole spigot near to size at 3.2mm then turned a short length at the end down by 0.01mm at a time until the wheel fitted. If the fit was too loose, then I brought the tool back by under 0.01mm on the next few millimetres in on the length until the wheel fitted snuggly, then cut the whole length to that diameter. I then cut the spigot to length and drilled the spigot 1.8mm for tapping an 8BA hole for the screw.
I then tapped the 8BA hole using the tailstock and tap holder to make sure it started square.
I then fixed the tyre to the wheel centre using two small patched of 188 solder paint, and my Weller 100W iron to get it done quickly.
The spigot was fitted in the main body of the holder using cyanoacrylate glue. I also fitted a peg (from a turned down 10BA screw) to engage with the spokes of the wheel centre since the forces in turning tyres with a form tool can be quite large and the peg would be needed to deal with them. note the first attempt which was too near the rim.
This was the first version of the spigot, where the spigot was split and the tapped hole was only partly cut with a taper tap so that a screw would open out the split and lock the wheel when the screw was tightened. This didn’t work as well as I had hoped, so I made a second version which used a collar to hold the wheel in place.
The second spigot is now in the holder body and the screw and collar are on the lathe topslide.
This is holder being set up to run accurately in the four jaw chuck using the dial test indicator.
I'll now have to continue on another message to finish off the pictures since I've hit my limit.
Jim.
