timbowales
Well, it arrived this morning. As it is not 7mm details and pictures will appear in my thread Cwm Gwendraeth BachHaving read this thread I've just ordered one of his Taff Vale brake vans, only in 4mm![]()
Interesting, Bill.Just my tu'pence worth...
W irons: Full-sized axle-guards were made from 3/4" steel, so if I can print them to scale in 4mm, I'm sure others can do the same in 7mm.
Resin: "Standard" resins are OK for blobby fantasy figures with lots of spikey bits to land supports on, but they are too brittle for use on the finer parts of railway models. Luckily, most resin manufacturers now produce ABS-type resins, which are tough and will withstand normal handling. Or Siraya Tech blu could be used, which will survive where an ABS-type fails.
3D printing should be more than sufficiently resilient to stand up to model railway - including exhibition - handling.
I'm more than happy to send you a kit to try - but you'll need to supply the wheels! I print in ABS like resin so doubtless the wagons will last forever. As long as you kep them in the shade . . . PM me and I'll sort something out. Or send me some wheels and couplings and I'll assemble and paint??? I moved from Acomb a few years ago otherwise I would have strolled round and hand delivered it!If @Broadgauger or anyone else wants to test the durability of 3D printed wagons, I'm sure the NRM layout could assist.
That brake van does look tempting, you naughty thingBrimming over with enthusiasm from Rod's build and some subsequent whatsapping (or maybe "what's occurin' " given Rod's background) I have added a few variations on the theme of short, 5 plank dumb buffered wagons.
The basic design lends itself to inside and outside strapped variants with plain, raised and curved plank ends. A request for something suitable for the Pembroke and Tenby Railway spurred thing along.
Would there be any interest in pre-formed, drop in loads for these? Barrels, bricks, crates etc?
I was also commissoned to do Pembroke and Tenby brake van in 4mm. The orders will flood in for that.
AndrewView attachment 236750View attachment 236751View attachment 236752View attachment 236753View attachment 236754
Thanks for the insight Nick. Sigh. I hadn't noticed that detail. Back to the drawing board . . . maybe.The 5-plank wagon looks great, and I like the optional ends.
The only thing I would say about the 5-plank is it has a through-plank over the door (in other words, the door doesn’t go all the way to the top of the sides). This adds strength, and is characteristic of mineral wagons - those for merchandise had full height doors. Loads such as barrels and crates wouldn’t make much sense in a wagon of this type, though they might be of interest to go in other wagons.
Nick.
Nick.
Andrew
But that just means the doors are wrong. Doesn't it? I'll release these as RTR in OO with wheels etc. soon. Purchasers of those models are pretty forgiving. Thankfully.
... Purchasers of those models are pretty forgiving. Thankfully.
Yes - maybe. I can't pretend to know enough about standards. The Chinese wheelsets I use are cheap but prety accurate. There is room to puh them out on the axle between the W irons but not sure about wheel profile or whether there are a hundred and one options in EM. It wouldn't be as siple as droping in a 'standard' UK axle as the ones on the model are 25.4mm over pin points. And 12.5mm diameter. But the model is based on a single photo so inaccurate wheel diameter may be the least of anyone's worries. I will add it in various forms to ebay - body parts, RTR with footboards. RTR without.Will it take EM gauge wheelsets?
Thanks Nick, that's helpful information.The 5-plank wagon looks great, and I like the optional ends.
Nick.
Interesting, Bill.
my experience is that it is absolutely possible to print axleguards in FNG, and they can look excellent too, but resilient, they ain’t. Now, maybe I’m clumsy, or I’m unlucky, or both, but it’s just too easy to break resin prints. They fail in a brittle manner, like china, and if you haven’t lost any bits they’ll superglue back together, like china, but I don’t want to be trying to fix axleguards.
maybe if the axleguard, axlebox and spring were printed as one, the combination would be tough enough.
