Although I haven't posted for 3 or 4 weeks, steady progress has been made on the Shay.
Here are a few photos showing the work to date.
The smoke box, smoke box door and the smoke stack are now finished, The hinges and fixing clamps on the smoke box door are dummy, the front is removed by unscrewing 2 socket head screws. The idea is to allow good access to the smoke box for fitting the plumbing.
I have made the fire grate and ash pan which hinge independently and drop by pulling a spring loaded knob.
The ash pan is made from 2mm brass sheet folded and silver soldered together.
The ash pan is 100mm long, rather than cut individual parts I annealed the brass and , using my 300mm long shear, press brake and roll machine
managed to press the brass to about 75 degrees.
The next task to make the drain cock, water site gauge and the blower pipe work.
The glass tube has yet to be cut to length, which will be done much later on in the build (don't want to break it).
The parts for the water gauge were quite fiddly to make but the end result seems OK
That's about it at the moment. Some bits and pieces to make and complete then the cab is next on the list.
Hope you found this interesting
