Steve Cook
Its been nearly a year since I did anything on the Ruston, and although John D's christmas card didn't mention it this time round, thought I ought to get the etches out and carry on.
Nothing too exciting to report, the cosmetic axleboxes were built up from the etches supplied (3 per axle box) - a slightly fiddly job to keep them all aligned whilst soldering - then a quick passs with the file to get rid of the cusps. The footplate was removed from the brass sheet, rivets punched, then the lower edges folded back over themselves and soldered on. A couple of the rivets are very close to the bottom edge, so next time around I'll aim to punch them at the very edge of the half etched holes. The axleboxes were then soldered on, a quick tack joint from the rear, a sanity check to ensure they were lined up (there are half etched lines to help with this on the hidden side of the footplate), then soldered on properly. The sides were then folded down, the footplate resting on a piece of glass with a block of wood underneath to get the clearance for the front buffer beam riser.
The risers for the cab floor have been folded up in the shot above. The front buffer beam was cleaned up, two plates soldered on the rear for supporting the sandboxes and then the assembly soldered to the footplate.
Alas, a quick dry run on the chassis showed that the front sanding pipes I fitted now clash with the sandbox mounting plates - my fault, I deviated from the instructions and didn't double check That'll be tomorrows job then, removing the pipes and mounting them closer to the bottom of the chassis...
Steve
Steve
