I recall suffering rather badly after a good knees up in there a few years ago. 5 or 6 or maybe 7 pints of the Kiora Orange lookalike stuff. Must go back, but stick to the ale instead!Tuckers Grave in Faulkland near Radstock is similar and still going as far as I know although I've not been over there for a couple of years. Cloudy cider...........apple madness
Jerry
Obviously an "acoustic" guitar so no wireing problems at all, except for what gauge strings to use
Chris, you should have mentioned that you were learning to play when you visited me!
Phil
I don't remember the walk back to Norton St Philip where we were staying. Apparently we went into the Fleur De Lis as well and downed 6X
The room in question is 'mother's', she sits in her armchair rocking slowly to and fro
Hi Chris,
A standard acoustic or electric would have been easier to start with - easier to fret steel strings than 'cat-gut' (dont tell your charming little furry friends that I used that word and that you are strumin away on one of their relatives!).
I have just looked again and it appears that you have cat gut (nylon) and wire-wound
You may have found that EAB was an easier key/progression to start with
Good luck
Kind regards,
CME
Not much; like you, I have a high backscene. But I couldn't get it all in, so had to take a shot looking upwards a little to get the top of the chimney in, and then merge the two shots as well as dropping just a little 'sky' to cover one of the built in light which you'd see top right otherwise. Cheating? Yes, but not too much...I was thinking, that must have been some camera to produce a shot like that, also with the sky and smoke, you must be a dab hand at dodging and burning
Phil
