Opened the box for the Collett 4000 gallon tender and then noticed that the axles need 2mm extensions. One of the three Slaters’ wheel packs has them, the other two don’t. The correct set is apparently old stock and the extensions must be bought separately. The story doesn’t end there, though. Just be warned when ordering the wheel sets that you must order item 7319 as well, except it isn’t listed on the web site and AFAICS cannot be added to the basket.
I had a set of axles for my 47 on which the wheels were pushed, not screwed, the axles had extensions to run in outside frames, they may have had an "MF" suffix. They were fine.
I had a set of "normal" Slaters' wheels and axles for my Hall, which was provided with 6 strange things that looked like a CSK screw with a spigot sticking out of the top. These were to secure the wheels on the quartered axles, and to provide outside bearings. They were horribly non-concentric and caused dreadful wobbling of the tender which had one fixed and two equalised axles. I have no idea who made or supplied them, as they came with the kit, and I seem to recall throwing them away, keeping the wheels and axles for another tender with inside bearings and buying a set of the axles with built in extensions to fit to the Hall. I used the same on my 28, which is rather more recent.
So if item 7319 is equivalent to the strange things, I'd guess Slaters will supply something better than the ones I had, which were definitely from the "dogs breakfast" school of engineering.
atb
