Finally... something for myself. Some GWR wagons from the Victorian era and running during my period of interest (being 1910-1914)... intended for the GW&GC Jt model and suitable for Scruft's Junction. The starting point is some kits which were produced by Meteor Models in 2013 although I suspect that the patterns go much further back. If making patterns for a covered wagon then putting planking on the inside surface of the ends seems overkill... until I remembered that Richard de Camin offered parts for the GWR four wheel open Siphon and I think that the pattern for the end of that vehicle has been used for this kit. So what do you get for your money?
The pressed roof looks reasonable and shall be used.
The axleguards and springs seem OK and are likely to feature in the build.
The buffers look nothing like the prototype (see below) so I shall have to source some alternatives.
The coupling hooks and links are just plain naff by the standards of today and shall be replaced.
The hand brake levers, the V-hangers and the brake lever guards are cast poorly, replacements required.
Brake block, hanger and pushrods; hmm, tricky, not easy to replace so maybe need some TLC.
I have no idea as to the purpose of the cube to the bottom RH corner, suggestions?
Spring steel wire for the buffers... we shall see.
Brass wire... for what?
Plenty of parts that really do not cut the mustard today, I think that finding suitable replacements is going to take time and that task is likely to lead to a lengthy build time for these wagons. One decision made is in regard to the coupling hooks, a no-brainer here - parts have been obtained from CPL (@PJBambrick).
As for the resin parts, two sides and two ends, these are cast in RTV moulds and are not necessarily flat.
Here is a photo of the prototype when withdrawn from revenue service and in use by the Locomotive department.
This photo has been posted on WT before, by Richard (@Wagonman ), and without attribution. The condition of the van suggests that the photo was taken in the 1930s which leads me to believe that the photographer was L E Copeland.
[for completeness, I believe that this kit is no longer available from Meteor Models, when I bought my models I purchased all of the remaining stock].
