tomstaf
Hi,
I've been working through my test etch of body parts for the HJ 31, and so far so good. Here are a selection of pics showing some of the parts. They are designed to be easy and very quick to attach. They simply need to be glued on, or folded up and glued on. No soldering is involved! It's all stainless steel for strength, and correct effect (eg window push down strips).
![HJ 31 1 sml.jpg HJ 31 1 sml.jpg](https://www.westernthunder.co.uk/data/attachments/29/29567-bd43e9e419341dc8482b2af3a639f1ea.jpg)
You get:
If you want the body etch above I'll be ordering some at the end of the month. The body set is £10. If you want a set(s) let me know asap by PM.
Tom
You get:
- Headcode panels, and separate etched rings for the rubber grommets. I'd paint the rings black first, and then glue after the headcode panel is painted.
- Screen washer covers.
- Extra brackets on the cab handrails
- Battery box clips - 2 types, straight and angled as they usually were. Again, I'd recommend painting these whilst on the fret and gluing to the model after.
- Strengthening plates on the bottom of the cab doors
- Fold up high intensity headlight
- Windscreen wipers
- Window top push down strips.
Tom
