richard carr
Heres a bit more.
I wanted to get a decent size speaker into the loco, SWD usually supply a 40mm round speaker with their sound chips. These are ok but the bigger the speaker the better they usually are and the more base sounds you are likely to get and a Deltic needs base. I have managed to fit a Visatron SC 4.7 ND that measures 71 x 41 x 30mm. Its a tight fit, you need to make a sealed speaker box for it thats slightly bigger. Here's the one I made up.
All the reinforcements in the bottom right hand corner of the above photos are so that you can file the outside away to get it to fit in the loco. In the photo above you can just about make out where I have filled it away to fit over the motor mounting. The top photo shows the completed box with the centre portion that has been cut out of the top.
This is how it fits in, its pretty close to the fly wheel.
And finally an image showing the side of the body after the respray with the painted quarter lights.
Note the deliberate tear to the data panel.
