Thank you, AdrianIt looks a sturdy little unit and any pillar drill is better than no pillar drill. I use mine daily so always a useful investment.
Hi Jon,Sorry to hear of your woes with the filler: back to Squadron, I guess, Jan?
Handy and sturdy bit of kit, Jan
You can’t beat ‘proper’ tools
Jon
To be perfectly honest although I have a small machine vice for the drill I very very rarely use it. 99% of the drilling is thin sheet and plastic so most of the time I hand hold it on a small hardwood block. For drilling brass bar stock or slightly bigger items I use engineer clamps to hold the material and then hand hold the clamps on the hardwood block. I just find it far easier to get the centre punched dimple under the drill that way.Next up is a small machine vice..... #itneverends![]()
Hi @adrianTo be perfectly honest although I have a small machine vice for the drill I very very rarely use it. 99% of the drilling is thin sheet and plastic so most of the time I hand hold it on a small hardwood block. For drilling brass bar stock or slightly bigger items I use engineer clamps to hold the material and then hand hold the clamps on the hardwood block. I just find it far easier to get the centre punched dimple under the drill that way.
It's only when drilling thicker steel bar or round stock - that I'll resort to the machine vice.
Steps Taken
A little progress on the Brake Van, and other things. The headspace hasn't been great these past few days, and the TTR has become more of a sanctuary than a workspace. But I've done some stuff.
The Basic box of the Brake Van has been built and some confirmatory research undertaken; I was wondering about the presence of the high mid-point side lamp in BR days - Tatlow's Wagons of the LNER shows it as being present on the GNR version, but I could find no photos of the later years. However, a request on The Clearing House FB group directed me towards DaveF's thread on RMWeb; and lo, my question was answered.... https://content-eu.invisioncic.com/...3044.jpg.a2af81260c12c930290f7047f5d24584.jpg So now I have to find some measurements for the footboard and associated handrail...
While I do that, I've been occupying my fingers (and mind) with some ScaleModelScenery cable drums. Lovely work and design... I've tried to do them justice...
I'm hoping to make it to Uckfiled over the weekend. If the weather is kind, and the car survives the 11 hour round trip....
Jan
Hello @Mike GarwoodJan
Interesting project - what's going to be used as a chassis? Just browsed the GWR range, these seem like an aid to scratch building. I like the multi-media approach.
I have built a few of this firm's kits in 7mm and I think that they have been developing their technology over time as the later versions are easier that early kits. For the LNWR carriages there is a neat jig to hold the various layers of the sides. Some parts are not as successful as others, but they seem to form the basis of some good rolling stock. At a slight risk of usurping Lyndhurstman's thread, here is a photo of a 7mm LNWR OCT which is built as it came, with the addition of wheel, buffers and couplings.Jan
Neat, JanWell Handled
The GNR Brake gets side rails.
I used 0.45 mm brass for this, and softened the ends of the horizontal rail so as to be able to squish it flat. Then, with the help of a rebate filed in the back of the two uprights, solder it up. Far easier to do than try to butt joint the ends…
It’s come out OK, I think. The bras is maybe too soft, so I might (MIGHT) revisit this with nickel silver instead ... The handrails are set 1 mm clear of the sides. I got this dimension from a GWR brake van diagram in Tourett et al.
Jan
Usurp away @Tim Birch. That’s very nice.I have built a few of this firm's kits in 7mm and I think that they have been developing their technology over time as the later versions are easier that early kits. For the LNWR carriages there is a neat jig to hold the various layers of the sides. Some parts are not as successful as others, but they seem to form the basis of some good rolling stock. At a slight risk of usurping Lyndhurstman's thread, here is a photo of a 7mm LNWR OCT which is built as it came, with the addition of wheel, buffers and couplings.View attachment 200832
which makes the assembly ‘interesting’.Intriguing - new to me & looks nice. Judging from the instructions I guess we have to source axle boxes and brake gear as well.I have built a few of this firm's kits in 7mm and I think that they have been developing their technology over time as the later versions are easier that early kits. For the LNWR carriages there is a neat jig to hold the various layers of the sides. Some parts are not as successful as others, but they seem to form the basis of some good rolling stock. At a slight risk of usurping Lyndhurstman's thread, here is a photo of a 7mm LNWR OCT which is built as it came, with the addition of wheel, buffers and couplings.
Hello @jonteNeat, Jan
Jon
Hello @adrianIntriguing - new to me & looks nice. Judging from the instructions I guess we have to source axle boxes and brake gear as well.
This kit is intended to reduce the time, complication and labour associated with the construction of a model of a railway vehicle. It uses wooden parts which have been cut and scribed by laser. This is not a complete kit of parts. The choice of wheels and other fittings is left to the modeller
