Dave Holt
I have continued to work on the dummy inside valve gear, blending a mix of parts from Dave B's J39 etch and new parts produced for me by Rumney Models. The latest additions are the suspension links and reversing gear. Here they are seen temporarily fitted into position so that the bottom ends could be soldered to the eccentric rod assembly. The latter is located using a 0.8 mm drill bit which will be superseded by brass/N/S wire for final fitment. I have tried the con rods in place, but these had been removed again prior to the photos.
![C13_031.JPG C13_031.JPG](https://www.westernthunder.co.uk/data/attachments/196/196784-83558180421f4f2f440a00034d389639.jpg)
![C13_032.JPG C13_032.JPG](https://www.westernthunder.co.uk/data/attachments/196/196785-1f13211627d706d9cfec6c6abb8646c6.jpg)
![C13_033.JPG C13_033.JPG](https://www.westernthunder.co.uk/data/attachments/196/196786-ed0533e2a63fa9f529c978f4516d8bc6.jpg)
Valve rockers and drive to the valves next. Then i suppose I'd better knuckle down and sort out the compensating beam issue and do the bogie and rear truck.
Dave.
Dave.
