Do it!!A Collett 0-6-2T, almost a temptation to go back 7mm....!
Getting some greenery around the rocks and the first pass of static grass
I hope to deliver Beattystone in a couple of weeks to the customer, he has a friend who has offered to make the gantries, once they are done I’ll install them and attempt to wire them up, we are not sure what to use yet wire or the EZ line like I use on the telegraph wires.The dioramas look much better photographed in daylight.
Being based aorund the Woodhead route have you given any thought to the 1500v DC catenary?
Many thanks for your kind words, Box has been a very enjoyable project. In a few weeks the owner professional photographer Jack Boskett will be collecting it and taking some better shots, this diorama along with an old favourite Mermaid cove will be on display at the Swindon model show at Steam 11th SeptemberSteve,
I always enjoy seeing your work on WT. I must say that with the Box Tunnel scene you have excelled yourself. In particular, the photo of the tunnel mouth, without a train shown in post 1264 is some of the most realistic modelling I've ever seen. Simply stunning.
Dave.
I used some EZ line as tramway conductor wire just over five years ago. I thought it was the bee's knees, especially when I could pull it out of the way for dusting. It is now dropping to bits. Then again, it would be straightforward to re-string it. The layout is in my house, usual environment with central heating and fresh air and so on.
I have suggested copper wire to the owner, I think they are going down the plastruct route as they want similar gantries to Woodhead Tunnel, until it’s made I won’t know and if we can then solder any where near it.I think building a representation of the 1,500v DC compound catenary and contact wires may be a tad too far and difficult with EZ line as you'd have to be having to create something like this.
This is one of my photos of Godley Junction (Manchester) taken in 1981.
And a close up of the compound catenary.
I'd stick with 0.35mm tinned copper wire as this can be soldered then painted a mid grey/green
