Hi Dan the grass starts out as a base of 2mm Noch summer blend, Then I blend noch 6mm straw with miniatur 4.5mm spring and summer green and build that up in layers.Comparing what you’ve done with the view through the window, the colouring is spot-on!
Is there a regular list of colours/makes that you use please Steve?
Dan
Thanks Steve.Hi Dan the grass starts out as a base of 2mm Noch summer blend, Then I blend noch 6mm straw with miniatur 4.5mm spring and summer green and build that up in layers.
Can you do a demo?Hi Dan the grass starts out as a base of 2mm Noch summer blend, Then I blend noch 6mm straw with miniatur 4.5mm spring and summer green and build that up in layers.
A pleasant few hours on a Sunday with the KESR project View attachment 208435View attachment 208434View attachment 208436View attachment 208437View attachment 208438View attachment 208439View attachment 208440View attachment 208441View attachment 208442View attachment 208443intentio Supplied the superb road signs and platform kit
Should there be some sort of tie bar to set the gauge on those concrete pot sleepers? I’m only really familiar with the GWR version, but it’s a feature of all the other variants I’ve seen details of.
I do that as well using an old sock to capture all the loose fibres, last year I upgraded to a WWS pro applicator and that is much better at making the fibres stand up. I use the cheap Chinese applicator for covering large areas of base grass.I use a vacuum cleaner to help lift the grass upright, just hover the nozzle of the vacuum cleaner a couple of inches above the freshly
laid surface . Oh and I put one of the wife’s stockingsover the nozzle to collect any loose fibres for future use.
I
Martyn.
I will have it with me next week for an in person closer lookSteve, having looked at these photos, I'm quite pleased I missed seeing it last week. I believe that by studying the smaller image I'm getting far more details coming out at me. Never quite appreciated it like this!
regards Rog
