Nearly finished now, someone asked at Reading how I would be doing the pick ups, so here it is, may as well share with all.
I'm sure there are many ways to skin this cat but this is how I do it. A pair of copper clad strips are joined with insulated bus cables, these are 1.5 mm and are rigid enough to stop the copper clad strips from twisting, therefore only needing one fixing screw.
The front screw also doubles as the motor mount, in this case a simple single coil of 0.8 mm brass, it's rigid enough to support the motor but has a slight give in it to allow it to float.
Wipers are 0.5 mm phosphor bronze wire with a little nook in them to centre them on the rim, they tend to be less prone to dirt this way.
The back head is finally finished and having taken the photos, I've just noticed some unsatisfactory solder that needs cleaning up on some of the oil lines. It's near unnoticeable by eye but once blown up on the screen really obvious, and now that I know....it has to go. A waft of paint and picking out of details will complete the sub assembly.
Next up will be glazing, lamp lenses, doors, hooks and other niff naff, leaving only the scratch built firebox base and sides to add along with the blast nozzle assembly which is easily viewed down that massive hole of a chimney.
![IMG_8317.jpg IMG_8317.jpg](https://www.westernthunder.co.uk/data/attachments/115/115194-7f142699274dbc8a8516f8a173e1ead0.jpg)
