Mickoos European dabblings
Magnificent Mick
A great model. even if it is damaged.
Richard.
Yeah, you do have to sit back and look at the bigger picture after the initial rant stage has passed.
Limited edition, top of the catalogue museum quality model with full lighting and smoke effects, plus lit display case.
The deflector bracket straps are a total write off, you can see where someone has tried to solder them on the inside, luckily the deflector material is quite thick so it hasn't rippled/buckled them but straightening them almost certainly will. I'll remove the lacquer, unsolder and make new ones.
The smoke box front looks like a broken lug on the inside at the top, luckily the smoke box door opens when you release all the locking lugs, it does reveal the big ugly smoke generator.
