This week I have been in Chicago so I have been using the time to work on the 56 bogies.
These are very detailed with well over 100 parts per bogie but the end results are worth all the work involved in making them, even if as Steph has pointed out there are still a few minor details missing.
Here's an almost finished one.
Anyone spot the deliberate mistake !
I can't believe I managed to do that, all fixed now though.
Here's how this all goes together, the first thing to do it to fit all the brakes and brake levers. These just snap into the holes in the etch all a really nice fit.
Then I added the air cylinders these two parts to each of these a casting and a small etch so another 12 parts per bogie to add to the 24 parts for the brakes and levers.
Here are the first 2 brake cylinders, these I have glued on with super glue.
Once those are added you then need to make up the axle boxes and suspension items there are 7 parts in each of these 6 per bogie so 42 parts per bogie.
So when you fit the 7 parts together you get that at the bottom of the above photo. The very to item has sneaked in and isn't part of the axlebox assembly.
There are a total of 12 of these to make and the first 2 seem very fiddly to put together but fortunately you soon speed up making the rest of them.
Again the the castings are very good quality and the holes int he etched parts are just the right size for a gentle force fit. The springs might not look it but are handed and have the boss to attach to the frame slightly to the outside, they will not fit in both holes if you get them the wrong way round.
Again I just stuck these on with super glue.
Thats the first one in.
And an hour or so later they are all in. I would point out I had spent quite a bit of time cutting all the etched parts out with scissors and cleaning them up before Christmas.
So here are the 2 largely finished bogies, there are still some dampers to add and retaining wires etc but they do look really good if you ask me and are worth all that time to put them together.
![20180131_065649.jpg 20180131_065649.jpg](https://www.westernthunder.co.uk/data/attachments/83/83497-f888ae644dbd3807935fdabdd90b7eed.jpg)
