The front class 33 has to be a Heljan one, the cab roof cowling is the wrong shape (doesn't slope on top), the front of the cab roof is not quite right and all the beading etc is a bit chunky. While looking at photos to double check I noticed that the top panel is missing from all the cab roof cowlings on photos taken from the 1970s onwards - if it is blue it should have rectangular holes cut in the top of the cowlings and the horns added.View attachment 134591
Must be my Gray period....
Can anyone work out which is a kit and which is RTR?
Have the best Christmas you all can.
See you next year
Correct.The front class 33 has to be a Heljan one, the cab roof cowling is the wrong shape (doesn't slope on top), the front of the cab roof is not quite right and all the beading etc is a bit chunky. While looking at photos to double check I noticed that the top panel is missing from all the cab roof cowlings on photos taken from the 1970s onwards - if it is blue it should have rectangular holes cut in the top of the cowlings and the horns added.
Hi, which Kadee coupling option have you used on your easybuild Mk1 coaches please?
Regards, Tony
#804 or #805 with side lugs removed and 1mm plasticard glued between ribs.
an unusual vehicle not one I've seen before - forgive my ignorance - what is the purpose of the barrier coach? I presume it's acting as a barrier but between what?Easybuils HST Barrier made up from spare parts found in my Workshop
