The Stewarts & Lloyds Limited's 6-wheeled No.25 built by the Yorkshire Engine Company in 82 is the ultimate 6-wheeled ogee built for British networks far as I'm aware,
thetransportlibrary.co.uk
though some others were exported after this date.
en.wikipedia.org
Nice to know about Andrew Barclay's clean switch in tank styles
Have never researched them or Barclays & Co in great detail but they certainly did build some smart boxes, the former's Works No.133 sold to The Dalmellington Iron Company was a right monster though! While capacity and adhesion would take a hit can't argue ogees do have the edge for visibility when shunting so that might be the reason, though when it comes to Neilson there isn't always much rhyme.
Below is their earliest ogee I'm aware of.
The angle isn't the kindest but it appears the cylinder pipes are not exposed so this stepping stone design is presumably from 1860 or a little after. That said the crank pin holes are between the spokes which doesn't gel with the later pattern that Bob Ridley/Phoenix and the eBay photo example sported so a little hard to judge on just this early 67 photo.
Pinkie is the next earliest 4-wheeled example I'm aware of and the more standardised piano & round saddle design that Neilson churned out can very much be seen, the 1888 engine in your post above being something of a throwback in terms of its exposed frames.
A few other Scottish firms built boxes and pianos for a time too, no doubt a fair bit of transferring talent and direct copycatting played their part.
1008 1864 0-4-2 Outside 4' 8.5" Caledonian Railway No.243 '216 Class' Delivered in 64
1009 1864 0-4-2 Outside 4' 8.5" Caledonian Railway No.244 '216 Class' Delivered in 64
1010 1864 0-4-2 Outside 4' 8.5" Caledonian Railway No.245 '216 Class' Delivered in 64
1011 1864 0-4-2 Outside 4' 8.5" Caledonian Railway No.246 '216 Class' Delivered in 64
1012 1864 0-4-2 Outside 4' 8.5" Caledonian Railway No.247 '216 Class' Delivered in 64
1013 1864 0-4-2 Outside 4' 8.5" Caledonian Railway No.248 '216 Class' Delivered in 64
1014 1864 0-4-2 Outside 4' 8.5" Caledonian Railway No.249 '216 Class' Delivered in 64
1015 1864 0-4-2 Outside 4' 8.5" Caledonian Railway No.250 '216 Class' Delivered in 64
1016 1864 0-4-2 Outside 4' 8.5" Caledonian Railway No.251 '216 Class' Delivered in 64
1017 1864 0-4-2 Outside 4' 8.5" Caledonian Railway No.252 '216 Class' Delivered in 64
1018 1864 0-4-2 Outside 4' 8.5" Caledonian Railway No.253 '216 Class' Delivered in 64
1019 1864 0-4-2 Outside 4' 8.5" Caledonian Railway No.254 '216 Class' Delivered in 64
1078 1865 ?-?-?T Outside? 4' 8.5" 10" cylinder tank owned new by A. Wilson who constructed the Esk Valley Railway. Authorised 21/07/64, first sod cut 05/09/64, Esk Valley Junction-Polton opened 15/04/67. Later owned by Wm. Black & Sons of Stanrigg Colliery, Airdire 05/72
1082 1865 ?-?-?T Outside? 4' 8.5" 12" cylinder tank owned new by Waring Bros & Eckersley who constructed Solway Junction Railway. First sod cut 28/03/65, opened to freight 13/09/69 & to passengers 08/08/70 (some sections earlier).
*There is an outside chance this was an 0-4-0ST ogee No.'6' or '8' was snapped in Jan 67 near Richmond Terrace. This concerned the Metropolitan District Railway contracts which Waring Bros was also involved in. Then again it might simply be another Neilson.
1083 1864 2-4-2WT Outside 4' 8.5" Great Eastern Railway No.140 'V Class'
1084 1864 2-4-2WT Outside 4' 8.5" Great Eastern Railway No.141 'V Class'
1085 1864 2-4-2WT Outside 4' 8.5" Great Eastern Railway No.142 'V Class'
1086 1864 2-4-2WT Outside 4' 8.5" Great Eastern Railway No.143 'V Class'
1087 1864 2-4-2WT Outside 4' 8.5" Great Eastern Railway No.144 'V Class'
1088 1864 2-4-2WT Outside 4' 8.5" Great Eastern Railway No.145 'V Class'
1089 1864 2-4-2WT Outside 4' 8.5" Great Eastern Railway No.146 'V Class'
1090 1864 2-4-2WT Outside 4' 8.5" Great Eastern Railway No.147 'V Class'
1091 1864 2-4-2WT Outside 4' 8.5" Great Eastern Railway No.148 'V Class'
1092 1864 2-4-2WT Outside 4' 8.5" Great Eastern Railway No.149 'V Class'
1093 1864 2-4-2WT Outside 4' 8.5" Great Eastern Railway No.150 'V Class'
1094 1864 2-4-2WT Outside 4' 8.5" Great Eastern Railway No.151 'V Class'
1095 1864 2-4-2WT Outside 4' 8.5" Great Eastern Railway No.152 'V Class'
1096 1864 2-4-2WT Outside 4' 8.5" Great Eastern Railway No.153 'V Class'
1097 1864 2-4-2WT Outside 4' 8.5" Great Eastern Railway No.154 'V Class'
1098 1864 2-4-2WT Outside 4' 8.5" Great Eastern Railway No.155 'V Class'
1099 1864 2-4-2WT Outside 4' 8.5" Great Eastern Railway No.156 'V Class'
1100 1864 2-4-2WT Outside 4' 8.5" Great Eastern Railway No.157 'V Class'
1001 1864 2-4-2WT Outside 4' 8.5" Great Eastern Railway No.158 'V Class'
1002 1864 2-4-2WT Outside 4' 8.5" Great Eastern Railway No.159 'V Class'
1122 1865 2-2-2WT Inside 5' 3" Dublin, Wicklow & Wexford Railway 'Ariel' 'X1 Class', replaced in 88, sold to contractor R Worthington & Co in April 89.
1123 1865 2-2-2WT Inside 5' 3" Dublin, Wicklow & Wexford Railway 'Kelpie' 'X1 Class', withdrawn in 89, sold to contractor R Worthington & Co in April 89.
1124 1865 2-2-2WT Inside 5' 3" Dublin, Wicklow & Wexford Railway 'Kate Kearneyl' No.27 'X1 Class', later 'X1a Class', withdrawn in?
1125 1865 2-2-2WT Inside 5' 3" Dublin, Wicklow & Wexford Railway 'Banshee' 'X1 Class', replaced in 91, sold to contractor Fisher & Le Fanu in June 94.
1126 1865 2-2-2WT Inside 5' 3" Dublin, Wicklow & Wexford Railway 'Titania', withdrawn in 89, sold to contractor R Worthington & Co in April 89.
1127 1865 2-2-2WT Inside 5' 3" Dublin, Wicklow & Wexford Railway 'Oberon', replaced 91, sold to Murphy's Brewery March 91.
1130 1865 2-2-2 Outside 4' 8.5" Follow up order by Said Pasha of Egypt? for Egypt Railways /Egypt Railway Administration
1131 1865 2-2-2 Outside 4' 8.5" Follow up order by Said Pasha of Egypt? for Egypt Railways/Egypt Railway Administration
1144 1865 2-2-2WT Inside 5' 3" Dublin, Wicklow & Wexford Railway 'Elfin', replaced in 91, sold to Murphy's Brewery in April 92.
1145 1865 0-6-0 Inside 4' 8.5" North Staffordshire Railway No.75, later 84.
1146 1865 0-6-0 Inside 4' 8.5" North Staffordshire Railway No.76, later 85.
1147 1865 0-6-0 Inside 4' 8.5" North Staffordshire Railway No.77, later 86.
1148 1865 0-6-0 Inside 4' 8.5" North Staffordshire Railway No.78, later 87.
1149 1865 0-6-0 Inside 4' 8.5" North Staffordshire Railway No.79, later 88.
1150 1865 0-6-0 Inside 4' 8.5" North Staffordshire Railway No.80, later 89.
1151 1865 0-6-0 Inside 4' 8.5" Great Northern Railway No.420 '400 Class'. Ordered 6th Dec 64, stock date October 65
1152 1865 0-6-0 Inside 4' 8.5" Great Northern Railway No.421 '400 Class'. Ordered 6th Dec 64, stock date November 65
1153 1865 0-6-0 Inside 4' 8.5" Great Northern Railway No.422 '400 Class'. Ordered 6th Dec 64, stock date November 65
1154 1865 0-6-0 Inside 4' 8.5" Great Northern Railway No.423 '400 Class'. Ordered 6th Dec 64, stock date November 65
1155 1865 0-6-0 Inside 4' 8.5" Great Northern Railway No.424 '400 Class'. Ordered 6th Dec 64, stock date November 65
1156 1865 0-6-0 Inside 4' 8.5" Great Northern Railway No.425 '400 Class'. Ordered 6th Dec 64, stock date November 65
1157 1865 0-6-0 Inside 4' 8.5" Great Northern Railway No.426 '400 Class'. Ordered 6th Dec 64, stock date November 65
1158 1865 0-6-0 Inside 4' 8.5" Great Northern Railway No.427 '400 Class'. Ordered 6th Dec 64, stock date December 65
1159 1865 0-6-0 Inside 4' 8.5" Great Northern Railway No.428 '400 Class'. Ordered 6th Dec 64, stock date December 65
1160 1865 0-6-0 Inside 4' 8.5" Great Northern Railway No.427 '400 Class'. Ordered 6th Dec 64, stock date December 65
1161 1865 0-4-2 Outside 4' 8.5 Scottish Northern Eastern No.58, later Caledonian Railway No.516 '58 Class'
1162 1865 0-4-2 Outside 4' 8.5 Scottish Northern Eastern No.77, later Caledonian Railway No.517 '58 Class'
1163 1865 0-4-2 Outside 4' 8.5 Scottish Northern Eastern No.85, later Caledonian Railway No.518 '58 Class'
1164 1865/6 0-4-2 Outside 4' 8.5 Scottish Northern Eastern No.86, later Caledonian Railway No.519 '58 Class'
1165 1865/6 0-4-2 Outside 4' 8.5 Scottish Northern Eastern No.87, later Caledonian Railway No.520 '58 Class'
1166 1865/6 0-4-2 Outside 4' 8.5 Scottish Northern Eastern No.88, later Caledonian Railway No.521 '58 Class'
1167 1865 0-4-2 Outside 3' 6" Queensland Government Railways No.5 'A10 Class'
1168 1865 0-4-2 Outside 3' 6" Queensland Government Railways No.4 'A10 Class'
1169 1865 0-4-2 Outside 3' 6" Queensland Government Railways No.7 'A10 Class'
1170 1865 0-4-2 Outside 3' 6" Queensland Government Railways No.6 'A10 Class'
1171 1865 0-6-0 Inside 4' 8.5" Great Northern Railway No.440 '400 Class'. Ordered 7th Feb 65, stock date March 66
1172 1865 0-6-0 Inside 4' 8.5" Great Northern Railway No.441 '400 Class'. Ordered 7th Feb 65, stock date March 66
1173 1865 0-6-0 Inside 4' 8.5" Great Northern Railway No.442 '400 Class'. Ordered 7th Feb 65, stock date April 66
1174 1865 0-6-0 Inside 4' 8.5" Great Northern Railway No.443 '400 Class'. Ordered 7th Feb 65, stock date April 66
1175 1865 0-6-0 Inside 4' 8.5" Great Northern Railway No.444 '400 Class'. Ordered 7th Feb 65, stock date April 66
1176 1865 0-6-0 Inside 4' 8.5" Great Northern Railway No.445 '400 Class'. Ordered 7th Feb 65, stock date April 66
1177 1865 0-6-0 Inside 4' 8.5" Great Northern Railway No.446 '400 Class'. Ordered 7th Feb 65, stock date May 66
1178 1865 0-6-0 Inside 4' 8.5" Great Northern Railway No.447 '400 Class'. Ordered 7th Feb 65, stock date May 66
1179 1865 0-6-0 Inside 4' 8.5" Great Northern Railway No.448 '400 Class'. Ordered 7th Feb 65, stock date May 66
1180 1865 0-6-0 Inside 4' 8.5" Great Northern Railway No.449 '400 Class'. Ordered 7th Feb 65, stock date May 66
1188 1865 0-4-2WT Inside 4' 8.5" London Chatham & Dover Railway No.81 'Iona', later SECR 540 'Scotchman Class'
1189 1865 0-4-2WT Inside 4' 8.5" London Chatham & Dover Railway No.82 'Bute', later SECR 541'Scotchman Class'
1190 1865 0-4-2WT Inside 4' 8.5" London Chatham & Dover Railway No.83 'Jura', later SECR 542 'Scotchman Class'
1191 1865 0-4-2WT Inside 4' 8.5" London Chatham & Dover Railway No.84 'Arran', later SECR 543 'Scotchman Class'
1192 1865 0-4-2WT Inside 4' 8.5" London Chatham & Dover Railway No.85 'Islay', later SECR 544 'Scotchman Class'
1193 1865 0-4-2WT Inside 4' 8.5" London Chatham & Dover Railway No.86 'Staffa', later SECR 545 'Scotchman Class'
1194 1865 0-4-2WT Inside 4' 8.5" London Chatham & Dover Railway No.87 'Ulva', later SECR 546 & 546A 'Scotchman Class'
1195 1865 0-4-2WT Inside 4' 8.5" London Chatham & Dover Railway No.88 'Clyde', later SECR 547 'Scotchman Class'
1196 1865 0-4-2WT Inside 4' 8.5" London Chatham & Dover Railway No.89 'Kelvin', later SECR 548 'Scotchman Class'
1197 1865 0-4-2WT Inside 4' 8.5" London Chatham & Dover Railway No.90 'Spey', later SECR 549 'Scotchman Class'
1198 1865 0-4-2WT Inside 4' 8.5" London Chatham & Dover Railway No.91 'Annan', later SECR 550 'Scotchman Class'
1199 1865 0-4-2WT Inside 4' 8.5" London Chatham & Dover Railway No.92 'Tay', later SECR 551 & 551A 'Scotchman Class'
1200 1865 0-4-2WT Inside 4' 8.5" London Chatham & Dover Railway No.93 'Nith', later SECR 552 & 552A 'Scotchman Class'
1201 1865 0-4-2WT Inside 4' 8.5" London Chatham & Dover Railway No.94 'Esk', later SECR 553 'Scotchman Class'
