Here's 3 little jobs that I chugged through whilst waiting for parts for the Atlantic to appear.
This is a Connoisseur J39 chassis that has had inside motion retro fitted and has passed through a few hands. The fella who was fitting the motion up to the chassis unfortunately died and I was tasked with finishing the job. The original kit laminated rods had been replaced with Premier Component rods. I think that someone had made the assumption that they would be a straight swap, but I had to take the horn guides off the frames and reset the axle centres using my jury axles and the new rods as a jig. It worked very well after that. The loco is fitted with AGH wheel sets and the insulated wheels had crept on their axles and the quartering was out on a couple of wheels. In my experience this is a common fault on this type of wheel, especially if the axle centres don't match those of the rods. Any consiquent binding can often force the wheels to creep on the axles making the matter worse. If your chassis is binding not at 3 or 9 o'clock that's a sign that the quartering is out or you have a crankpin issue. Check your AHG wheels all have the same quartering.
Someone had designed some nice inside motion parts and had them 3D printed and cast at Shapeways. They had been assembled with lots of machine screws, but the screws couldn't be tightened up on the rod joints as they would prevent free movement. This meant they had a tendancy to unwind themselves and crash into the screw head next door that had become loose too. I soldered the screws in place and ground all the adjacent surfaces flat. A couple of other joints needed a bit of relieving to prevent binding and off it went.
The next job was a loco bought off Ebay (I think?) by a client who wanted it converting to S7 and giving a bit of an upgrade. It has all the hallmarks of a Geoff Holt built loco but had been repainted quite badly. I stripped the paint and moved the large splashers outboard a bit to accomodate a S7 wheel set. Colin Dowling reprofiled the Walsall Industry wheels for me with S7 Soc form tool and added some S7 axles. They all dropped nicely back into the chassis and I had to rebuild the brake rigging. I added some new clacks and a new boiler handrail and it went off to Warren Haywood for a lick or two of paint. It came back to me last week and I have reassembled it and popped some coal in the tender. I think it looks rather resplendent in it's new livery.
The third job was the reassembly of a GWR Broad Gauge Armstrong convertible I made a couple of years ago. It had been opened and inspected by customs agents on it's way to Australia. I suspect that customs had dropped it and it arrived in Melbourne in a very sorry state.
Jeff Ennis of Scorpio kindly provided some etches for a new cab and I was able to make the loco as good as new with some new whistle turrets. The courier's insurance scheme did pay out to cover the cost (I would suggest that insurance is essential on all models sent by post.) Warren has made a fabulous remedial paint job on the loco.
3 happy customers I hope.
