Thank you JB and AJC.
Adam, I know that I am stretching the date boundaries a bit with this model, but the whole point of it is a memorial to our departed friend; Steve Baldock!
His greatest passion was for all things steam, and road traction in particular. I chose the last type of Sentinel built for the home market as the only appropriate and likely type to be seen operating at roughly the period of the railway.
Thanks too for The Lion link. Super isn't it? It is just a shame that it doesn't seem to have been updated lately!
Anyway, here is my latest...
It is not just the original, prototype doors that are flimsy!
It needed some very careful drilling of four holes into the leading edge of mine for the tiny loops.
When they were superglued and set in the door I gently tweaked them to a 45 degree angle, toward the outside of the door.
That part is critical!
The hoops are also slightly wide as well, but that will allow a bit of vertical play, thus ensuring that the door will both swing freely and seat snugly in it's frame.
This is the part that I described as being not too bothered about last night!
The moulding was going to be chopped up anyway.
This time, two 45 degree angle slots were cut into the pillar, again slightly wide to allow that vertical movement of the hinges.
Unfortunately, the overscale nature of said moulding is now a slight problem; the hinge gaps are much more prominent than I would like!
Two rather scruffy little pins were shaped, then sprung over the loops before insertion into holes drilled in the pillar slots!
This is the worst, and most wasteful part of the operation.
Parts that are inclined to ping away are a right pain in the postern?!
But worth the aggro in the end...?
A happy chappie, after sipping from his mug of hot chocolate held in one hand, while merrily opening and slamming the door with the other, was able to sleep contented last night!
Pete.
