Heather Kay
I managed a short test run on The Plank. All the lights worked, but pickup was awful. So much clag on the wheels.
First job this morning, then, was to clean the wheels. I also tried to mop up a lot of the grease that the gear trains tend to expel. I don’t need to weather the underframe to represent diesel spills! With the wheel tyres a bit shinier, a quick tootle on the rolling road showed it sort of worked okay. Sadly, I don’t think my tiny Gaugemaster handheld controller is quite up to the task. It needs full power to get the thing running at all, so I assume it can’t supply sufficient angry electron pixies for both motor bogies together.
I’ve done a quick visual check that the final drive gears, which are still OEM nylon jobbies, haven't split. My goodness, isn’t there a lot of slop in that gear train‽ No wonder it throws grease everywhere!
Having satisfied myself the mechanicals and electricals are within tolerance, I suppose I need reunite the chassis and body, and sort out the final little details.
