Spent the last week endeavouring to raise my flagging enthusiasm for the hobby after my long line of failures.
This is my solution(?) and last ditch attempt. If it even dares to go the way of its predecessors, I’m throwing in the towel….
It’s a self contained base board measuring 5’ x 16”, 4’6” of which will be scenicked, and built using traditional methods of 12mm ply for the surface, glued and screwed to a 2”x1” PSE frame.
There’s also a 3’ fiddleyard adjoining which utilises a baseboard joiner I’ve had for many years, rescued along with other bits and pieces as they headed for the inevitable bin. This will be supplemented by split hinges as per my ‘Monks’ layout. Cassettes - again as per ‘Monks’ will be the choice of fiddleyard operation.
And here I’ve boobed already: following ‘Monks’, I boarded over the whole frame, only realising last night that, unlike Monks, I won’t be using cork underlay due to the very low backscene, designed for easier carting around and storage. Only part of the frame should have been boarded for storage of the cassettes……… Hence, a second trip to the wood yard. Still, I suppose it could have been worse.
I won’t harp on, apart from to say that the backscene is removable on three sides: the rear, left side adjoining as you look from the front, and the whole of the right side. Experience has shown that trying to work around a fixed backscene is a pain, so this will almost full access. Once I’ve ‘finished’ the project, it can be fixed down securely. I’ve also installed a drop-down door to the left side via a piano hinge to enjoy a look over the buffers and out along the station throat to supplement the single traditional view from the front. Well, that’s the idea.
The proscenium arch is yet to be fixed in place and just placed for the photo, and all the screws will be removed and the holes filled for aesthetics.
This shouldn’t have taken a week, with most of it spent in contemplation, as there was no plan as such, just an inkling of what I wanted, but add to this the fact that all I have at my disposal in the form of tools is a low cost drill, a couple of screwdrivers and a (blunt saw), and absolutely no idea as to how to cut straight! Hence, most of it was ‘jigged’ up on the bench, which accounts for the plethora of holes!!
Oh, and btw, it’s going to be yet another GWR BLT…………
(Apologies for the poor quality photos).
