Not quite sure I've fully taken onboard the 'race' aspect of this build
I've spent most of the day working out how to modify the door assemblies and making handles.
The door on the right is folded up as per the kit. What it misses to my eye is that the angle iron should sit behind the front face of the doors rather than be level with them. I removed both sides by scoring with the Olfa cutter until I could just flex the brass and break it along the score line. Both cut edges were cleaned up, then some spare strip was solder back into the doors, but flush with the new edge. The removed piece had the top angle reduced slightly, then this was soldered to the new edge giving the detail I wanted as per the doors on the left above. Its the same detail I added onto my GBL so I couldn't leave it off this one
The door catch is on the wrong way round - I think it should 'point' to the right, but there is a big hole under there to help with soldering so I've stuck it on as is. The hole in the left hand door has been sleeved down to 0.9mm to take the new T handles.
Handle wise, top left are what I think are the main locking handles, made from 30thou wire soldered into a slot cut in some 3/32" wire. I just cut a deep slot in the 3/32" wire, put the 30thou wire in, clamped the top of the cut together then soldered it all up. It was all then trimmed to size and filed up. The 3/32" section is long so it protrudes through the door where it can be epoxied into position.
The same technique was used to make the 'pull' handles on the right, except the wire was formed into a U shape, annealed, then bent at 90 degrees. The T handles are 0.9mm nickel silver wire, soldered together then filed to size. With it all mocked up into the first pair of doors
I have to say I'm enjoying the RSU for adding the detailing bits, its become a pleasure and results in next to no cleaning up which is even better
Suppose I better cut out all the parts for the next three door pairs then...
Steve
