Hi Adam
That’s a smashing job you’ve made there!
May I ask how you intend to operate the blades, please?
Hope you don’t mind but this one I cobbled together in OO Gauge from some scraps of PCB, b/h rail and leftover C&L chairs.
As you can see, there was no ‘set’ in the curved stock rail, having resorted to the old dodge of filing a slot in the stock rail for it to nestle into.
Looked okay I think from a distance, but the rail should have been raised to suitably accommodate the chairs (the rail being merely soldered straight to the PCB).
I simply soldered the single switch rail to the sleeper and you might perhaps just make out the operating tab attached to the side of the ‘moving’ sleeper, the intention being to operate it via SPDT switch linked to wire in tube.
The top photo shows what was intended (the under sized sleepers were to be buried in the ballast/detritus of the yard).
Hope you don’t mind, Adam, and I’d like to hear how you intend to operate it.
Best wishes,
