Just enough time to take a couple shots before the light fades on the glorious south coast.
Most of the paint has been stripped away, leaving a few few stubborn areas that I'll tackle tomorrow. I feel a bit thick headed after those stripper fumes, even after opening the bay windows.
View attachment 11539View attachment 11540
Now the paint has been largely stripped away I can see exactly how badly this kit has been constructed. As Neil mentioned above, the join between the cab bodywork and the roof is awful - nowhere near where it should be. I don't know if even the most liberal amount of weathering is going to hide this! You can't tell from these pics, but even the roof fan is way off centre by quite some way.
To answer the questions posed so far, I'll have a proper look at the bogies later tonight but the centre wheels don't budge a micron. They have either seized, been painted solid or soldered in position. That's going to be one hell of a job on its own.
Jordan, I should have titled this Laughing in the Face of Stupidity. Way more more apt!
D7093, thanks for that insight. There is a wire connected from one of the motor poles to the bogie chassis which would account for that rather basic approach. I will put them on the rolling road later tonight and see what happens. They are quite stiff though.
Both cab ends plus the body sides toward the cab ends are quite distorted. You can just about make out on the second pic above that the buffers point toward each other. This, unfortunately, is not a photographic error...
Thanks all for your encouragement. I'm going to need all I can get!
Steve
