iploffy
OC Blue Brigade
Or even Obi-wan Kanobi using his light sabre to cut out door framesYou do realise that NONE of it will work unless there is a 7mm scale blagger being thrown onto the bonnet of the 7mm Granny by a 7mm Regan? Don't you?
I have had problems wiping off previous layers of acryilic trying to add mortar .......I would be interested in your solution .............never had these problems with enameli just need a good way of sealing the surface before I apply them
I see, that wouldn't work for me as the surface is verticalThe problem isn't the acrylic comming off, it is the wash soaking into the Mdf. I apply mortar dry and spray water onto the surfactant to activate it, I find a damp mix just too abrasive
I do know someone who would sculpt some masters... Hmmm, dunno what the demand would be thoughCynric I remember an episode when the villains run off through some sidings being pursued by Regan and Co they are being repeated on Sky at the mo isn't that a good cameo scene to copy it had two levels and a main line and the baddies ran over all of them
Polyfiller and pigment, so it can be coloured to suit. Very high tech!What is the powdered mortar ?
Many years ago, not long before it was retired from the exhibition circuit, I was operating Trevor Nunn's Wicken. As this was set in the Fens, he decided to make it look damp in places, using stragetically placed pools of gloss varnish.That is bringing to mind all sorts of gross visions mostly involving sneezing on the model,
We'll seeJust thinking, how will you marry up the join on the under arch brickwork to the vertical brickwork?
