taliesin
Further progress has seen the window glazed, also the roof and chimney pot fixed on,
The roof was initially glued on with the Aliphatic resin glue, then a bead of Araldite was run inside around the joints by using the hole in the floor, the chimney was fixed using the Araldite after painting and spraying with Dullcote,
The chimney was finished off with a bit of roofing lead available from Dolls House suppliers,
Just an alternate view, still need to source a door Knob but not the end of the story.........
cheers to all, Rob
cheers to all, Rob
