Heather Kay
If I can do it, then there`s hope for everyone !
Hang on! I was here first!
If there is any downside to adopting S7 then the expectation that the majority of steam loco kits are going to be an easy conversion may be a tad economical with the truth. Where an intention to build an o-FS "designed" kit to S7 comes unstuck is with parts which relate to both side of the frames at same time, for example:-Even ready-to-run models can be converted to run on S7 track, relatively easily.
I must confess I don't understand that comment - can someone please explain?
I modelled in P4 and P:87 for many years before jumping to 0-gauge and never had a problem with running reliability. In fact, with the better defined standards than 7mm f/s in some ways it ran better!
....Both my Fowler 4P and Standard 5 are purposely built as bad as I can get away with, with regards to perfection (horn guides and bearings etc) but both roll through West Mersea with consummate ease and neither have S7 flanges as of yet. .....
Well - last time I walked the four foot at West Mersea, there did seem to be an awful lot of broken chairs.......
Sounds like a new member to me Hester..!
Scratch building in S7 is so much easier than in O/fs
JB.
Well somebody had to ask, unsurprisingly it's me; so why do you perceive that scratchbuilding in S7 easier than f/s?
(Being curious, rather than argumentative )
Purely because you can work directly from works drawings without having to think about cutouts in boilers for splashers, and correct width cylinders etc... No adaptation needed for narrower wheel sets and frames...
Once you've modified a few kits to work in S7 you realise just how many fudges there are to make a kit suitable for O/fs..
JB.
Been there got the t-shirt! My first Scale7 build was my Y10 Sentinel and is a rigid chassis, albeit a very short wheelbase!You could probably build rigid chassis in S7
And through the A6 turnouts of Scrufts Junction.All our original S7 builds are rigid. John Lewsey now owns our LNWR G2, which apparently runs well through the Hartley Hill track work, even with its unsprung and fine scale profile tyres.
