I have been after a kit of a 2884 for a long time, originally Pete ( JLTRT ) told me he was going to bring one out, but it never materialised. So, I thought I would try the kit Scorpio had on offer, I only needed the loco as I already had a spare Finney 7 tender. Jeff at Scorpio was happy to supply just the loco.
On inspection the etches were crisp and clean and I couldn’t fault the price which included the Slaters wheels (optional extra). The only thing I wasn’t sure about was the method of using two rocking beams on both sets of drivers, and what was also different was that instead of the usual inside beam method these where sited on the outside of the frames and the plates (beams) also incorporated the brake shoes. Now I have been told these actually work very well but I decided to cut out the main frames and install Slater's brass horn guides and blocks, see photos below.
Below are the rocking beams supplied.
Below, I am setting out the datum for the height and spacing of the hornblocks and guides.
As per usual with me, it's one step forward two steps back. In all kits the mainframes have the axle holes already etched in place, whereas because of the rocking beam design I am left with no datum to work to, oh dear.
Obviously, this is a very crucial part of any build as I need to get the coupling rod spacing exactly spot on, and the ride height. So, I prepared the two main frames and temporarily tacked them together then I pinned the rocking beams behind of where they would normally be sited, this then gave me hopefully the correct spacing for the axles. Rather than using engineers blue which I find very messy, I use a felt tip pen to highlight areas that need marking and then scribe gently the exact markings. Right, so out with the piercing saw, wish me luck.
I have scribed on the mainframes exactly where the horn guides are to be spaced using the couplings rods that I always use from Bill at Premier Components, being an 8 coupled loco I like the rods jointed and you can’t beat milled rods in my opinion. So, using a piercing saw I gingerly cut out the opening for the horn guides, I was concerned about the ride height but what does help there is a small witness mark halfway up the Slater's horn guides
One of the frame spacers needed notching out as the hornguides protrude inwards, but not a problem.
And the final photo, shows the frames and rods in place.
Voila, one free-wheeling chassis, always a bonus when there aren’t any tight-spots or binding. I placed some weights on the chassis to compress the springs and the ride height is spot on, what a relief. I was out of my comfort zone because there were not the usual etched holes in the chassis to help with setting up the rods and ride height, so down tools and off to the garden for a beer or two.
Martyn.
