John Walker
I think I am beginning to understand what is required.
Using the eccentric rods as a guide is difficult because their position changes with the setting of the reverser so we should concentrate on the eccentrics.
The position of the eccentrics is described well in the final paragraph here:
http://kesr-mic.org.uk/resources/Stephensons+Valve+Gear.pdf
Applying this to the Kirtley Goods I know from the drawing that the forward rods are in the centre and the right hand connecting rod leads. Assuming outside admission valves (I am not sure how to determine this from the drawing) each eccentric should lead its connecting rod in the direction of travel by 105.5 degs. So, I reckon it should look like this:
Right hand connecting rod leads (say to the right)
Backward rod leads (bottom + left a bit)
Forward rod leads (top + left a bit)
Forward rod leads (right + up a bit)
Backward rod leads (left + up a bit)
Left hand connecting rod (bottom)
I think this matches the position of the eccentrics on the right hand side on the drawing.
The best match I can find using Laurie’s eccentrics, which are pinned to the cranks, is:
RHS 2FF1F34F
This seems to set the angles at 90 degs rather than 105.5 degs but I guess that would allow the kit to cover more variants.
Adrian, that is almost your suggestion but it gets the forward and backward rods on the RHS the wrong way round.
I think it may be time to put my logic to Laurie. I did speak to him at Brightwell but didn’t really get very far.
John Walker
RHS 2FF1F34F
John Walker
