Want to check that the company will take some to the event?Ill have a couple of metres
OK, I've run into a problem.
I tried to buy 2m of this, but my order was below the minimum value by some margin, and there's nothing else I want.
Richard,
If you've got problems getting some rod, I'll be popping down to Al's Hobbies in Bristol to pick some up for myself and could get some for you at the same time
http://alshobbies.com/shop/cat.php?id=1023
Jim.
Carbon (fibre) rod wouldn't be fantastically useful for this job as it tends to conduct electricity...
Bristol Kite shop is on Cotham Hill - so it's also on the north side of Bristol. They're the guys I bought my GRP rod from: http://www.kitestore.co.uk/
That I didn't know. I knew carbon rod does - like in my RSU - but I somehow considered carbon fibre rod to be an insulator.
Jim.
He he - for some reason it's not common knowledge, but effectively carbon fibre is graphite; so yes it's conductive.
It might be an apocryphal story, but a good friend of my Dad's use to work at Ciba-Geigy at Duxford where they were early developers of carbon-fibre pre-preg material. Such that I had a day touring the factory in the mid 80's. Amongst the many stories he had was one where they caused an electrical blackout over part of Cambridge. As it was early days the filtration system wasn't brilliant and quite a few stray carbon fibres escaped, quite light they floated in the air like dandelion seeds. Given the number vented to atmosphere more than a few ended up at a local sub-station where due to their conductivity they unfortunately shorted a couple of cables and tripped out the electric for part of Cambridge!He he - for some reason it's not common knowledge, but effectively carbon fibre is graphite; so yes it's conductive.
The conductivity of carbon fibre also causes big problems in aerospace, lightning strike protection on carbon fibre composite wings needs a lot more careful design than the traditional aluminium alloy construction.
Is it any more of a problem than driving your highly conductive motor car? Having been struck by lightning countless times whilst at work over the past 40-odd years, apart from a bit of scorched paint and the odd rivet head burned off, damage has been remarkably small - a testament to the robustness of the design, manufacture and maintenance of modern transport.I wonder if Uncle Bernie has considered the interesting effects of racing F1 tubs in a thunderstorm?
Richard,
Jim.
Yes it is much "more of problem" with carbon fibre. Despite the carbon fibre being a good conductor it is embedded in a nice insulator, the resin. So the carbon fibre panels as a whole are poorer conductors, in the case of lightning strikes it can cause much more localised heating, which the resin doesn't like, the current would then try to find the path of least resistance, which in an aircraft wing may be the fuel tank, actuator cables etc.Is it any more of a problem than driving your highly conductive motor car? Having been struck by lightning countless times whilst at work over the past 40-odd years, apart from a bit of scorched paint and the odd rivet head burned off, damage has been remarkably small - a testament to the robustness of the design, manufacture and maintenance of modern transport.
No argument with any of that but the original comment which provoked my reply was related to a F1 car which although having a carbon fibre body is surely insulated from the ground by four very substantial rubber tyres rather like a normal car. With the highest point standing about a metre above the ground it hardly presents an easy path of least resistance in comparison to the plethora of alternative paths around the racetrack.Yes it is much "more of problem" with carbon fibre. Despite the carbon fibre being a good conductor it is embedded in a nice insulator, the resin. So the carbon fibre panels as a whole are poorer conductors, in the case of lightning strikes it can cause much more localised heating, which the resin doesn't like, the current would then try to find the path of least resistance, which in an aircraft wing may be the fuel tank, actuator cables etc.
Returning to the engineering aspects of these spilt axles - please can we have some details of the method of construction, including:-
* drill size (or sizes) for the bore through the axle;
* epoxy brand / specification;
* how to get the epoxy into the axle bore without clagging (a good Wessie term that) the internal screw thread;
* mandrel speed when turning the radial groove.
Cynric - what is the run-out of the axle end after the final manufacturing operation?
