Thanks for the comments guys. I must admit it's been interesting to see the number of 'views' and 'likes', but a bit strange when the thread itself only had my meanderings for a while there...
Anyway, on to tonight's pressing engagement. (Pun intended)
With eight laminations of the coupling rods requiring joggles to make the knuckle joint work I realised I'd need a way to quickly and accurately form the necessary tight s-bend, otherwise it could take me hours. It'd also be a problem as regards accuracy, imposing slightly different lengths in the rods. By the way I should add that this isn't meant as a criticism of the kit in any way - it's a prototype detail that I love and I usually make my models up with coupling rod joints on the knuckle. (Go-on someone; ask...
So lets have a quick look at what we're setting out to achieve:
Now in terms of the tool I used some scrap 0.040" (1mm) brass I had knocking about. Well, I say brass, it's awfully soft so I supect it's actually gilding metal. Here it is with the two halves seperated showing the forming surfaces (of 0.015" brass). When the tool is together they're actually around 0.5mm apart - forming the distance between the concave and convex bends shown above:
In use, a coupling rod is carefully prepared to fit as perfectly as possible over the tubular peg (this is the material I'm going to use to form the knuckle pin):
The two halves of the tool are bought together, before being clamped up in my bench vice:
And once seperated again, out pops the finished article:
Time to make the tool was about half an hour and each formed lamination takes about 15 seconds to do. Time well spent, I think.
So I should get the rods finished this week. Which'll be nice...
