This photo looks “right”
Can you feed the chain with the gearbox in this position?
Possibly stupid question - can the gearbox go at the other end?
(Which presumably means the bogie about face?)
Thanks Mike. I have a JLTRT 52 and that's >2mm wider inside the bogie frames than Steve's kit. With that Slater's GB13, I'd have to lop about 3mm off the Delrin sprocket. Have you pinned yours to the axle?Hi Steve,
for what it's worth, here is a view of my take on the JLTRT Class22 underside which may help. This used a Slater's GB13 gearbox and their Delrin sprockets and chain - like yours, it was a tight fit.
best of luck with your build.
regards
Hi Steve,Thanks Mike. I have a JLTRT 52 and that's >2mm wider inside the bogie frames than Steve's kit. With that Slater's GB13, I'd have to lop about 3mm off the Delrin sprocket. Have you pinned yours to the axle?
Thanks Brian, that's interesting. I was wary of cutting down the Delrin sprocket too much, but maybe that would have avoided so much fiddling with the gearbox.This what I did with a JLTRT 22. Can't remember if it's Markits or Roxey, probably Markits. I cut the delrin sprocket down by a couple of MM and I see I did pin them on this model. I have used these loads of times on all my JLTRT models and they all run fine.
Thanks Tim, I actually bought a drive belt kit from them to try out. Unfortunately the pulley is significantly larger, with negligible scope to cut it down, so I couldn't use it.These drive belts from First Class Kits are great, much easier to use than delrin chain.
A superior range of O Gauge (7mm) Brass Etch Wagon Kits and useful modelling accessories
A superior range of O Gauge (7mm) Brass Etch Wagon Kits. Nearly Everything In The Box Bar The Paint!! First Class Kits also provide useful modelling accessories including Ball Bearings, Transfers, Delrin Products and many more….www.firstclasskits.co.uk
