Stevers' Stall of Shame
Stevers
A revised 1862 First with the extra unprototypical footboard brackets at each end to keep them straight(er). Close inspection of the tumblehome will reveal the pixellated steps that Anti-Aliasing (if genuinely available on the Mono 4K) might soften. Beyond it is an 1859 Pass. Brake sporting what I understand to be a 'Nine Elms' style caboose, painted, glazed and most importantly, safely separated from the edge supports and fitted without accident. This is the version raised by 0.5mm compared with the Weddell drawings to better match photos. Happily the templates I made for the original version now fitted perfectly! The double sided tape that I used to secure template to glazing had a more sticky and less sticky side. The stickier side needs to be on the template not the glazing - don't ask me how I know! The use of a brand new Swann Morton blade being essential when attempting to cut this (or probably any) sort of 'Plastiglaze'.
The very controllable Armstrong Whitworth DE shunter will be useful to shunt all these old coaches around, so I've been amusing myself by adapting the Mercian Models running plate to accept my 3D printed body. With the body being scale and therefore smaller than the Mercian etched body with thicker walls, clearances are now quite tight. I reduced the hole in the middle by edge soldering some 2 x 2 mm brass angle to give an upstand to locate and glue the body to. I then found that the added material interfered with motor mount and pickups requiring me to provide clearance via gapping the new upstand. When offering up the body to the running plate and viewing it from the front with a critical eye, I realised that the bonnet front had been printed on the skew with a distinct curve to the prominent radiator. I've also added the rear footsteps and am working on a solution for fitting the air tank across the back that can't be in one piece due to the rear steps with that wide bottom tread trapping the tank and/or the chassis.
Stevers
The CAD for a complete body with Knife Edge supports was all ready to print when I realised that the body I already had only needed a 'nose job'. It was easy (in 3D CAD) to cut off the back of the complete body and then to add an Airfix style joining flange. Allowance was made for the additive kerf, but some filing for final fit was necessary. The body was cut just shy of the nose panel line and carefully filed back for a perfect fit along the panel line. Truing up the nose has done wonders for the alignment of the rest of the body, and only that gap under the battery boxes lets it down. I'll probably pad that with styrene then file it flat. The nose was a small part that lent itself to printing without knife edge supports. In replacing the nose I was able to beef up the handrail brackets and the piano wire handrails are in position for the very first time.
The roof was scaled 1.002 in width and height and 0.998 in length. This made it fractionally larger and shorter than before and compensated for the 'additive kerf' that affects the fit of 3D printed parts. As can be seen it was printed without the benefit of knife edge supports to get things printing 'properly'. As I proceeded to cut the nose off, the resin this side of the bonnet fractured, happily once the cut was trimmed back I was able to invisibly epoxy it all back together again.
The other flavour of close coupled 3-set for the Downton Train Crash. Nearest is an 1862 First, then an 1862 Second and finally an 1865 Third. The First is unbraked, the Second and Third are braked and have pads on the nearer ends. All have the extra brackets to keep the footboards nice and straight. The First class was printed without Anti-Aliasing (AA), the Second and Third was printed with some measure of AA. The settings used were AA=4 and Gray Level=1. With AA on, the 'Cones of Calibration' tests became the 'Cones of Contradiction'. The cones would suggest over exposure when the sword fitted beautifully in the skull and wouldn't fit in either rock. Similarly the ale was a perfect fit in the mug. With AA exposure was increased from 2s to 2.4s. AA has softened the pixellated lines with no apparent loss of detail. AA was also employed on the new nose and roof for the AW diseasel. As can be seen in the photos above it is striking how low the roofline of these coaches is compared with the AW or my W Class.
Stevers
This is first of my yard cranes to be printed on my Anycubic Photon Mono 4K. A 'Verwood' crane in 7mm scale, I can just about squeeze it all (with the spreading Blueprint Studio supports) onto the tiny build plate. The frame has extra detail found on a set of pictures of near identical cranes found on the LBSCR. The print took just under five hours, and the Blueprint Studio supports came away easily before washing. The jib halves and pillar were printed vertically, and the gears and rollers horizontally, but there is little evidence of layer lines on any of the sloping surfaces suggesting that the Anti-Aliasing is at least partially effective. This has been dry assembled to check fit, and will be heading to the Netherlands.
