Another month passes - progress is made, but hardly so as you would notice...
I mentioned in an earlier thread that this is my second etched kit - there have been some areas, however, that I've rebuilt so many times that my total could easily have been 5 or 6 by now... The front end is a case in point.
In last month's thrilling installment I described the manufacture of the radiator cap. Due to my over-enthusiasm for attacking the gentle art of soldering with a gas torch as my weapon of choice I loosened the previously (wrongly) attached lamp bracket. I regarded this as a "happy accident" as it gave me the push I needed to fix it properly to the front (not top) of the radiator.
Looking again at the profile of the radiator, I came to the inescapable conclusion that I couldn't live with the profile of the radiator top.
As the parts in the kit initially fitted up, it seemed that the entire front end should be radiused, but the more closely I studied photos to try and determine the shape of the radiator cap, the more I came to the conclusion that the front should be a combination of radiused and square corners and that somewhere along the line I had bungled.
This photo of 06 003 stripped naked was the clincher as it showed exactly how the functional part of the radiator must be built into the front end.
There was no real option but to solder a short arc of wire into the offending area and reprofile the front end to something closer approximating the real thing.
At the same time I scribed a couple of lines to represent the panel to radiator joint, but these are not very distinctive - I may revisit these before painting.
I've also soldered in the grab irons at the front end - these ended up surprisingly square. Result! (although I won't say how many attempts it took....)
Current state of play.
The main things still to be done to the body are now really quite minimal: I've put off soldering on the rear footsteps for risk of damage, but these should be good to go; I'll make up some fuel tank filler connections for under the footplate; I need to get some worksplates ordered up pronto (I believe Diane Carney makes the best Barclay ones?); rear vacuum pipe was forgotten last month; sandbox fillers (these should be flush inset to the footplate, so I'll maybe drop these). Radiator grille and radiator ladder may or may not be fitted before painting - the jury is still out on these.
My aim is to get the body ready for painting within the next month - Given my rate of progress, the Norwegian winter seems awfully close. The winter here is not really conducive to painting - in fact the summer isn't that much better:
According to Wikipedia
"Bergen, Norway is one of the more famous European rain-cities with its yearly precipitation of 2,250 mm (89 in) on average". It seems like quite a lot of that 2,250mm has fallen in the last couple of weeks.
Finally for tonight - the Slaters' wheels for the Jackshaft drive have arrived. As I now have a "spare" set, I'll maybe experiment a little with reprofiling the spokes to give a better effect - the best two sets will be used and any disasters can be buried.
