And then there were (still) two...
So, one of the Vigentini/Metrop models turned up on a well known auction 'site (in the HO scale listings) a couple of weeks ago with a single line in the listing 'From the ABS models collection', so I'm assuming it's the model Adrian was referring to earlier in this thread that was previously owned by Richard Bollen. I was lucky enough to win the model, so with due apologies for a couple of hurried photos:
Unfortunately, as you can see, the model was crunched on it's way to me, but having just reached an 'accommodation' with the seller, now seemed the time to post. I'll almost certainly have to make a new cab side and I'll need to find some decals so it can be resprayed. Like Richard's model mine is a bit wayward on the wheel specifications for running (although probably right for one of the NMRA or MOROP standards) so is in the rainy day pile for now while I work out what to do about it (and Richard's loco as well). Having played with many r-t-r brass locos over the years, although most have been in HO, I'm sure a solution can be found.
The damage the model has received means I'm now considering turning the loco into a coal burner and refining the detail a little for use on a British layout; if it had arrived here in one piece I would have been much more circumspect.
