Rob Pulham
I wasn't sure where to post this but as I hope others will learn from my experiences this is perhaps the right place.
I finally got around to assembling the other side of the A3 valve gear tonight and I am having a few problems. the main one being that the reversing crank on one side wont stay tight and after travelling half way around then reverses itself.
This side works as it should rotating around the crank pin.
This side starts off tight and in the same position as the one on the other side and when going in reverse it seems to behave as it should. However when going forward it goes so far then, reverses itself and comes loose.
In order to get the clearances for the rods on the two from axles I have had to do away with the crank pin nuts and reverse the threaded crank pin bushes tightening them onto brass washers up against the wheel boss. I have though of soldering the reversing crank to the reversed crank pin bush but wanted to solve the problem before taking such a step - I don't want the crank pin bush to unscrew as well.
It is also worth mentioning that while going forward in spite of the reversing crank coming loose and only doing half the circuit it does run quite smoothly. In reverse it also runs quite smoothly for about 8 revolutions before it all tightens up with no visible reason why. All this is done with the motor loose on the axle and turned by hand.
All suggestions gratefully received before it turns into an unmanned aeroplane
