Ah missed this, just caught up and added to my watch list.
I’m impressed my 4mm attempt is truly awful by comparison!
I’ll resurrect it one day.
Looking forward to more.
Hi Mike, I was about to have a go at lunch hour at work now I’ve finished my Airfix wagons! As home spare time is on Meldon at present. Then Covid19 hit and put an end to that. So I’m sure come the end of this and back to work that will happen.Hi Ade
Please do resurrect your project. I'll be interested to see how you get on. One thing I've discovered is that when it comes to soldering it is handy to have some extra heat! I can't remember when I last used my 20 watt iron - I use my 100 watt iron all the time. It's probably a bit of an overkill with maybe 50-80 watts being optimal
I think I got mine from Cookson Knew Concepts | Jewellery Tools – CooksongoldImpressed by your piercing saw, I do need one of those too what was the source of that one please?
When a blade snags from time to time as they do I usually end up snapping the blade
Hi Mike,
An interesting little prototype and very nicely built. You seem to be posting one image at a time or 2 or 3 one after the other in separate posts. Is that by choice or are you not aware you can load and post up to 15 images per post?
As to a 100watt iron being over kill, no reason not to use it. I got by with a 50 watt Antex TCS for about 30 years building 7mm kits in brass and nickel silver, but recently moved up to a 65 watt Hakko FX 888d. It's not got the power of the Ersa 80 watt favoured by many, but I'm very impressed so far. All things considered, I nearly went for the Ersa, but read lots of good things about the Hakko and to be honest, the quirky appearance of the station appealed to me.
Cheers,
